Televison & Video Logo
sonya scribner Posted on Jul 24, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I use an antenna on my sharp tv catv? If so, what kind works for this tv
I want to cancel my cable and use an antenna instead. What kind of antenna should I buy for it. I am in a very busy city and my other tv runs on rabbit ears fine so I want to do my sharp tv also! To save money.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 24, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
373
Points
Hook up your rabbit ears and auto tune the TV and see what happens.
Andrew Lohbihler
Level 3:
Master:
  • Master 505 Answers
  • Posted on Jan 02, 2015
Andrew Lohbihler
Master
Level 3:
Master:
Answers
505
Questions
0
Helped
413174
Points
2258
Make sure your TV has analog service with an antenna connection, or a local digital provider transmitting to your antenna if the TV supports digital antennas. Usually antenna equipment providers have detailed signal information about antenna service. Try a simple antenna first before buying an expensive antenna system for your TV.
How do I tune my Sharp tv to channel 3 so the cable will work?
Go to the Tuner setup screen and select cable instead of air. Then put the TV on Channel 3 and connect the cable box to the antenna connector on the TV.
1helpful
Im trying to connect my unit to my tv to record shows and i having trouble doing so please help i am hooking it up wrong
For OTA or CATV signals, you need to daisy chain the coax from the source (antenna for OTA) to the coax input on DVD recorder and then the coax out to the coax input of the TV. If you have a set-top cable box with an incoming CATV signal, it should be connected between the DVD recorder and the TV.
The unit can tune in and record 480i (SD) ATSC (OTA digital), NTSC (OTA analog), analog CATV and digital CATV channels.
A satellite receiver or a non-CATV cable box should get the incoming signal first and then have their composite video output (A/V) connected to the DVD recorder composite video input and then their coax (RF) output (if present) gets connected to the TV. For these, you would record from the IN1 or IN2 (press Select Input) instead of selecting a channel. Then connect the composite video out on the recorder to the TV's composite video in.
Digital signals are either enough to tune in or give no signal. So check that your antenna is correctly oriented for OTA.
Separately, you can connect the video signal when playing DVDs via composite (good signal) out and component out (better signal) out to the TV's matching input. For the component video, the sound is carried on a separate cable. Then set the TV to the input source.
In the case of wanting to watch a VHS tape while taping to a DVD, do not use the Component video source, set the TV to Input 1 (composite).
I hope this helps.
(you can get a copy of the manual here: http://tv.manualsonline.com/manuals/mfg/panasonic/dmrez47v_dmrez475v.html )
A 96 model : 16-422 is stuck in HRC or IRC and we cannot manouver thru menu to change it back to CATV
HRC/IRC is CATV
Who is the manufacturer and Model ?
Older Sharp sets had a switch on the back near Antenna in.
Other sets have a "setup" in the menu that will let you navigate further to hooking up the TV.
How can i get my tv off catv? without a remote
Press the menu button on TV
Use the ch +/- and Volume +/- to move within the menu
Go to SETUP
Go to TV/CATV and the select TV
This will take it off of the Cable settings and put it back on Antenna
Good Luck...
1helpful
Hi Someone gave me this old Sanyo TV Model # 31C4760, When I connect it with my cable it catches only basic (13 channels) instead of 60 channels. How should I see all the channels? What should I do?
If it is very old (with rotory/manual channel changer), you are out of luck unless you get a cable box from your cable company - this will let you set your TV on channel 3 or 4 and the cable box will find all stations for you. The cable box goes between your wall cable and your TV.
It your TV has an electronic tuner with a remote, try going into the setup menu and select signal source as CATV instead of antenna.
Please rate me.
2helpful
Trouble with Channel setup
It is important for the TV to know what type of
signal-Cable TV (CATV) or a normal antenna
you are using. Choose your signal (Antenna or
Cable):
Press MENU to see the main menu.
Press CH+ or CH- to highlight Setup.
Press OK
to enter the Setup submenu.
TV/CATV is highlighted. Press VOL+ or
VOL-
to select TV or CATV.
Choose CATV if you have Cable TV
service. (See page 4 for connection
details.) If you do not have Cable TV
service and you connected an antenna
to the TV, choose TV. (See page 5 for
connection details.)
Press MENU repeatedly to exit the
menu or the menu will automatically
disappear within a few seconds if no
buttons are pressed on the remote
control.
And here is the manual if you need .
http://tv.rca.com/RCATV/Assets/pdfs/27F520T_1641312E_IB_e-06.pdf
Good luck and please rate
2helpful
2answers
Westinghouse 32" TV NO Singal rabbit ears
Buy a digital antena,or a roof antena set it up plug it in,the in hole said Input or Ant..Go to the menu select where said Cable or Air.Select Air for free Air Tv.Scan for channels.
Can't change TV to CATV mode
You must unplug the cable connecting the television and the cable box. Then turn the television off and then back on. Do not turn the cable box off or disconnect the cable in wire from the cable box especially if you use Cable Vision. It will take up to 20 minutes before the box comes back on. Now turn the television back on. When you access the Channel System menu, you have the access to the submenu choices. Change the Antenna option to CATV and the Current Channel to 3. Reconnect the cable box to the TV.
Also those that are having problems with the TV turning off periodically, make sure the sleep mode option does not have a number in it. For example, if the number is 10, it will turn off every 10 minutes.
I have my cable coax connected to the UHF, VHF, CATV input. If I connect cable to Digital Antenna In input and do channel search will I receive local digiatal broadcasts or do I need to split the coax to...
You need to put a compatible cable decoder box between the cable and TV as the sanyo will only decode analogue cable signals via the catv UHF vhf input
the digital antenna in is for digital air broadcasting signals only
2answers
HOW DO I SWITCH FROM CATV TO REGULAR ANTENNA IN THE MENU?
In the Setup menu there is an option to specify if you use an antenna or cable. Just switch it to antenna.
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
