Question about Furniture
I am looking to buy some bar stools for my kitchen island. Are there different types I can choose from or a standard type?
Posted by kkiss on
jessi h
    New Friend:
    Problem Solver:
  • 15 Answers
Bar stools come in three fundamental varieties: bar stools with arms and backs, stools with backs only and backless stools.
Posted on Jul 24, 2012
Hero Furniture Co., Ltd
    New Friend:
  • 17 Answers
Welcome to contact Chinese manufacture by email [email protected] Our factory is mainly produce Bar stool, Dining Chair, etc. Quality products and goo prices can be assured.
Posted on Feb 21, 2014
Tip
How do I convert numbers into Barcodes?
<p>Barcodes: inscrutable, energetic, and everywhere. These small computer-readable symbols on almost any product you use in your day-to-day. The surprising aspect of barcodes is simple as they really are. There are various bar code standards to be used at any time, but almost all standard bar codes work the same way: the lines of different thickness are arranged in a pattern that the various types of dates. Some patterns are purely numerical and other letters and other data types. By doing a bar code was quite the work of specialized software, it is now possible for almost any type of bar code by one or more web pages. <br /> <p><br /> <p>1. See what kind of barcode you want. Several facts about each site list bar code standards, including its intended use and what types of data can be stored in them. Read through the websites (or your own online research) and to determine which standard works best for your needs. Remember to position the barcode and what kind of scanner you want to read it to consider. <br /> <p><br /> <p>2. Choose a bar code generator barcode pattern chosen. <br /> <p><br /> <p>3. Follow the instructions on the site to generate your barcode. <br />
on Jun 26, 2011 | Computers & Internet
What is a "memory swivel"?
A memory swivel (or return swivel) is a type of bar stool that swivels but then returns to the original position once a person gets up. Most memory swivel stools only rotate 180 degrees.
Jul 24, 2012 | Furniture
My kitchen bar stools are amazing as far as style and comfort are concerned; however they are slightly too tall. Is there a way for me to keep these stools and simply shorten them a little?
Absolutely. You can shorten a bar stool without too much difficulty. I have found a great 5-step guide that will help you through this project. Hope is works out for you, would be a shame to lose your bar stools.
http://www.ehow.com/how_8632070_shorten-bar-stools.html
What type of bar stool is best for overweight individuals?
The best type of bar stool for someone who is overweight to sit in is a floor mounted stool. This type of stool is securely attached with bolts to the floor beneath it, ensuring better support and stability. If you don't want to bolt down your stools, your next best option is to get a four-legged stool. Four-leg bar stools disperse the weight of the person sitting on them evenly. On the downside, four-leg stools have a higher risk of tipping over.
I have a few swivel bar stools in my kitchen but two of them are squeaking, how can I fix them?
First turn the stool on its side and check all the bolts on the legs. If they are ok, rest the bar stool upside down so you can get a look at the underneath of the seat. Check the bolts there too. Once you are sure all bolts have been tightened return the stool to its upright position. Next you will need a can of high quality lubricant which you will need to apply to any squeaking area.
I am opening a small pub and will obviously need some bar stools; however I was wondering if someone could help me understand how much space is needed.
There are several factors you need to consider before buying bar stools for your pub. First, think about floor space (the amount of physical room on the floor the bar will use). The average bar stool will take up two square feet of floor space. Next is the height of the stools; which will obviously be directly affected by the height of the bar. There should be 10-12 inches from the height of the stool and the top of the bar. Lastly, you need to consider the distance between the stools themselves, for fear of overcrowding.
Are kitchen bar stools any different from commercial (pubs/bars) bar stools?
Essentially, there is no difference in the function of the stool; however the height varies slightly. Kitchen bar stools are 23-28 inches from floor to seat whereas commercial bar stools measure 29-32 inches.
What kind of paint and brush should I use to paint my wooden bar stools?
You should first put a layer of primer using wood primerfrom a spray can. This will prevent thepaint from being absorbed into the wood. After 24 hours, you should use acrylic black (or whichever color youwant) paint in a spray can. The reason Irecommend spray paint is because it's easy and gives you tan even, blemish freecolor. Wait 24 hours (so that bubbleswon't form) and do another layer. If itdoesn't look thick enough to you, wait another 24 hours and do a final layer. There is no need for a clear finish.
May 29, 2012 | Furniture
Furniture Logo
546 people viewed this question
Top Furniture Experts
Tom Chichester
ray gallant
Are you a Furniture Expert? Answer questions, earn points and help others
