Cars & Trucks Logo
Anonymous Posted on Dec 13, 2008
Dodge Diplomat rubber door
Where i found
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 14, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
65
Points
We git from saudia arabia
1helpful
How many gear changes does the 1985 Dodge Diplomat have in the gearbox?
3-speed automatic powertrain offered since October 1984 for North America U.S. Dodge Diplomat
1helpful
What is the power of engine dodge diplomat sedan 6 cylinder 1982
As per the link below, a whole 90hp! WOW! The older slant sixes had 145hp.
http://www.automobile-catalog.com/make/dodge/diplomat_dodge/diplomat_medallion_4-door/1982.html
1helpful
83 dodge diplomat carb leaks fuel
Float level and or needle and seat adjustment or replacement. Lovely engine. I had one once with 3 (three) twin throat Nikki carbies on the side of it and it flew Nearly
Heat ac door stuck
Doors also can be jammed by objects that have been placed on the dash and have disappeared down the defroster ducts. The cure here is to extract the object from the plenum by fishing through the heater outlet with a coat hanger or magnet - or removing the plenum.
God bless you
Heat door
God bless you
1983 Dodge Diplomat Why does horn sound weak?
Try replacing the horn fuse or relay to make sure you're getting a good supply of power. Check wiring connections at the horn to make sure they're clean, not corroded, etc. Figure out where the ground wire from the horn (usually black) connects to the body or wiring harness and check that connection. A bad ground can cause the problem you describe.
How to change the starter on an 87 dodge diplomat
Disconnect the battery negative terminal. Remove the one large and one small wires from the starter. Starter is secured to transmission with one bolt and one nut/lockwasher. I think they are 9/16" fasteners.
1helpful
How do you change oil in a 1986 dodge diplomat
its called the headliner. and you can fix it yourself but it is a pain. you can have it done for about $75 at a shop
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
