Clarify: #Error appearing immediately with sudden ****? or while carriage parking in serve station area?# remove & take out service station, place it out side(to avoid capping/wiping by cleaners)..check
# check carriage bushing warn out condition( too much play of carriage causes this error)
# trailing cable flexibility good? or its obstructing the carriage path?
# take out cutter assembly from rail.. check..
# Check carriage belt tension, adjust if required.
# Check carriage belt properly installed? re-install again
Best of luck....
Observe when 86:10 error appearing? after intializing the carriage or immediately after powering on?
# If immediately error appearing do the below discussed activity
# after intializing if error appearing check trailing cable,service station wipers & cappings,cutter position, cutter movement & lubrication on rail.
Detatch power cable & data cable,remove right door, pull out carriage assembly from service station area (if its locked by service station manually unlock it). Remove cable connections, screws & take out service station from the printer.Place the service station out side(ensure that cables has to fix properly) connect the cables,switch on the machine, check for the error..
if error is not appearing: check the service station, found any damage replace it or shoot the problem.fix it back..
*even error is appearing: Remove carriage belt from the pully..check carriage movement, if found any hardness/obstruction? shoot the problem.
Finaly: check trailing cable( while carraige movement some tracks may lose their continuty)
Power supply.. ( check voltages)
Need your feedback for further help.. [email protected]
