Used to print on card stock of 200grams , now it won't , keeps jamming
SOURCE: Card stock won't feed
HI,
SOLUTION:
Thanks
The problem should be corrected. If the problem still exists, service your product.
SOURCE: I purchased a C6280 all-in-one
We neeed to manually set the size of the paper in order to print on abaove paper sizes.
Open the HP Solution Center and click on settings >> print settings >> printer settings.
Now select the paper type as plain paper and click OK.
Now click on custom settings and enter the size of the paper and give it a name and click OK.
Now close the solution center and reopen it again.
Now click on settings >> print settings >> printer settings.
Now check whether we have the name that we gave to the custom size previously. Select it and then click OK and then try to print.
SOURCE: hp c6280 says was jammed now ink system failed
Reinstalling cartridges
SOURCE: Printing Envelopes
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print.
The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11.
I hope this helps.
Deny
SOURCE: My HP deskjet 2050 all-in-one
Any error messages on the printer digital screen or the desktop? I take it the "The ink is fine" means that there is ink in the cartridges!
Try a test print via the Control Panel> Printers and Faxes> properties > Print test page.
