SOURCE: my sony ericsson xperia continues
sol 1) go to menu and do a master reset (first with settings alone, if this does not work do a reset all - but make sure have a backup of all your phone contents ).
sol 2) if you have a pc suite or an SE Update service software installed in your system, try phone repair or do a complete software update. (this is completely user friendly and you can do this by your self)
but plssss make sure you have backup all your phone datas
SOURCE: Toi can tim code Unlocked Sony Ericsson Xperia X10 Mini E10i
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlocking.com which is doing good service .....you can approach this website.
SOURCE: how to turn on chinese writing for sony ericsson
You need to make sure you have chinese input method installed. You may check this in the settings-> Applications -> Manage applications or setings->Language & keyboard. If not, you can find and install one from the Android Marketplace. One of the good one could be the Google pinyin. Also, the fashion Swype input method also supports chinese input as a beta function, but you have to root your phone to install this. After this, you can check the setings->Language & keyboard to enable and setup the input method of your choice.
SOURCE: I am not receiving messgaes
Hi hemalekhaa,
To edit the message centre number:
Note: The message center number is provided by your network operator, you will need to contact their Customer Service department to get the message center number.
Quick Glossary
NCK = Network lock
SPCK = Service provider corporate lock
SPK = Service provider lock
Code formats you may receive for Sony Ericsson models:
Wherever possible we'll try and send you just a single unlocking code to unlock your Sony Ericsson.
However for certain models we may need to send you more than one code, even if you don't use them all.
It would be a sting of codes as per this example:
CCK: 0984118391686835 or 0984118391686835
ESCK: 0000000000000000 or 0000000000000000
NCK: 4176979876474847 or 4176979876474847
NSCK: 3908320398047435 or 3908320398047435
PCK: 2061751224321908 or 2061751224321908
SPCK: 9960493992337231 or 9960493992337231
Note: The NCK (Network unlocking code) is the main and usually the only one you'll need.
Please note:
- If you see the message 'NCK: (0)' or 'Not Allowed', this means the phone is hard-locked. The phone cannot be unlocked because there has been more than 5 wrong unlock attempts.
- If your Sony Ericsson has a Joystick, then you must press the DOWN Arrow instead of the LEFT Arrow. DOWN Arrow meaning Joystick downwards
Instructions
Unlocking Instructions for Sony Ericsson XPERIA X8
How to insert the Unlock CODE into your Sony Ericsson XPERIA X8
Camera won't work
