Question about Stanley Garden
61804 stanley backpack sprayer manual - Stanley Garden
5 Related Answers
Anonymous
SOURCE: Stanley 61804 does not "pump up" (compress air) ?
http://www.alamia.us/Solo_Sprayer_Parts_s/814.htm?gclid=CNvasPXY1ZsCFdVL5Qod3U4hJw
Posted on Jul 14, 2009
Anonymous
SOURCE: MY STANLEY 61804 DOES NOT PUMP. THE PUMP HANDLE
the darker Seal has come off the plunger at the bottom of the unit , easy 5 min fix , just unscrew the allen keys at the bootonm take off the cover and remove the plunger , you'll see the plunger seal still inside you can fish it out with an allen key or similar tool clip it on again and reassemble
Posted on May 31, 2010
Anonymous
  • 3 Answers
SOURCE: I have a Stanly backpack sprayer pro 61804n and
The picture looks a lot like a Solo sprayer I have. I wouldn't be surprised if Solo made them for Stanley. Do a search for Solo sprayers. They have a site. My sprayer is a Solo 425
Posted on Jun 28, 2010
Vinay Kumar
  • 438 Answers
SOURCE: Stanley 61804N Professional Backpack Poly
Doc,
Yes, please replace the seal.
Posted on Mar 05, 2011
mark24354
Mark T
  • 776 Answers
SOURCE: I need a new rubber
Drive out to the country side and look for a ACE or TrueValue hardware store. Bring your sprayer with you. They will likely have the right part for you in stock.
Posted on Sep 09, 2011
Looking for replacement Stanley 61814 backpack sprayer parts. Replacement spray nozzle. Know where I can get them?
Chapin makes sprayers. They have parts. Just give model #. Phone 1-800-950-4458. Located in N Y STATE. Pump rebuild kit is $25.00 Inc shipping.
Jun 18, 2018 | Stanley Garden
Stanley backpack sprayer top is stuck....... how do I get it off?
Hi Chris:
Seems a bit extreme to consider using the 12 gauge. I've found that a .22 works quite well. (Humour)
Hint! Pressurized tanks must have the pressure relieved BEFORE the lid can be removed.
If the lid has been over tightened or has stuck, you'll need to get more leverage to unscrew it. Sometimes a rag wrapped around it is all it takes.
You can also try pouring hot water over the cap. Lay the tank flat so the rim of the cap gets the heat. Wrap an old towel around it first so it gets a good hot soak.
Should come off without the artillery.
Cheers
Mar 19, 2016 | Stanley Professional Backpack Poly...
Parts sprayer stanley
I would like the answer yo that question
May 10, 2013 | Stanley Professional Backpack Poly...
I need a new rubber seal for the plunger piston on my stanley backpack sprayer. Where can I get one of these? Is there a web site for ordering these parts?
Sep 09, 2011 | Stanley Professional Backpack Poly...
Instruction,use,care manual not enclosed in box
call the 1-800 #
The manual is not available online.......Sorry
Feb 14, 2011 | Stanley Professional Backpack Poly...
I have a Stanly backpack sprayer pro 61804n and need a repair manual. Were could I find one. Thank You, Chuck
Jun 21, 2010 | Stanley Professional Backpack Poly...
MY STANLEY 61804 DOES NOT PUMP. THE PUMP HANDLE JUST POPS STRAIGHT DOWN EVERY TIME i TRY TO PUMP IT. ONLY USED 3 X. wHATS THE PROBLEM ???
Oct 29, 2009 | Stanley Professional Backpack Poly...
The spray unit bent and broke...
Lowes or Home depot sells replacement sprayers. Hose to tip all included.
Aug 18, 2009 | Stanley Professional Backpack Poly...
Garden Logo
518 people viewed this question
Top Stanley Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
mpservices
Are you a Stanley Garden Expert? Answer questions, earn points and help others
