Shows error 142, inspection required.
SOURCE: B6300n Printer: Hello i have oki B6300 printer and its showing e...
Step#1: Turn on power, press the left and right arrow buttonssimultaneously,, release both buttons then press the online button to get intothe DIAG. Menu Step#2: Press the down arrow button twice the operator panel willdisplay Diag.Menu Adjustment Step#3: Press the right arrow button the operator panel will displayAdjustment DC131 NVM R/W Step#4: Press the down arrow button the operator panel will readAdjustment DC132 Set Serial Step#5: Press the right button the operator panel will read SerialNumber XXX Record this serial number SYS1: XXXXXX Step#6: Press the Down Button 24 times. The operator panel should readDC132 Set Serial Target PWA SYS1 Step#7: Press the Select button Operator display Enter Serial No. 000000 Enter the serial number thatyou recorded in step#5 Action: Please reference this photo as a reference for the up, down, left, andright keys, when performing the following procedure. Step#1: Turn on power, press the left and right arrow buttonssimultaneously,, release both buttons then press the online button to get intothe DIAG. Menu Step#2: Press the down arrow button twice the operator panel willdisplay Diag.Menu Adjustment Step#3: Press the right arrow button the operator panel will displayAdjustment DC131 NVM R/W Step#4: Press the down arrow button the operator panel will readAdjustment DC132 Set Serial Step#5: Press the right button the operator panel will read SerialNumber XXX Record this serial number SYS1: XXXXXX Step#6: Press the Down Button 24 times. The operator panel should readDC132 Set Serial Target PWA SYS1 Step#7: Press the Select button Operator display Enter Serial No. 000000 Enter the serial number thatyou recorded in step#5 Step #8: Press the select button operator display Re- Enter Serialnumber XXXXXX enter the serial number from step #5 again. Press Select Step #9: The operator panel will displa Note: The Operator will now display "DC132 Set Serial NumberCompleted". Step #10: Press the left and right arrow button, release both buttonsthen press on-line button to get into the Diag MODE Step #11: The operator panel will display Exit Diagnostics Incomplete Exit Step#12: Press the down arrow button the operator panel will read ExitDiagnostics Complete Exit Step #13: Press the select button the operator panel reads Complete Exit If OK Press SEL Step #14: Press the select button the operator will read Please Reboot Printer (103-208) --Power the unit OFF Wait three seconds then power the unit back ON.Operation is now complete.--
SOURCE: unable to work on oki c5500n on dell x64
If you are using this printer w/ two different versions on it or if it is on a network you must install both drivers. Your printer has its own web id if it is hooked up to a network. You can go into devices on network, right click on the printer and go to device web page. The problem is you had it working w/ a more advance version and now you are reverting operating systems.
SOURCE: getting error 142 fatal error
unplug the unit then clean the printer and all drum units and etc with compressed air. Replace the drums and replug should solve the problem.
980
An error occurred like paper curling to the fuser unit.
