Hayward Super Pump 1 1/2 - Hp for In Ground Pools Logo
Brandt James Posted on Jul 24, 2012
Hayward super II wiring
Switching my new Hayward Super II pump from factory 230v to 115v. When arrows are lined up on 230v, only A terminal is being used. when I switch it to 115v It won't land without either bending terminal L2 down to also land on or bending it out of the way. Which do I do? Should it land on A and L2 when in 115v?
3 Related Answers
john224
John Prohaska
  • 1378 Answers
  • Posted on Jul 04, 2009
SOURCE: switching my hayward pool pump from 230v to 115v
Setting the pump for 115V wont by itself cause the trip. There is either a ground in the circuit or the GFI is bad. You may want an electrician to test any further than this.
james aurienne
  • 93 Answers
  • Posted on Jul 13, 2009
SOURCE: Going from 230v to 115v on Super Pump
open back you will see the bars to hook to it should show which is the right side 3wire only for 115
MOTORWIZJ
Jay Finke
  • 1397 Answers
  • Posted on Sep 08, 2011
SOURCE: I need to verify the wiring on a Hayward MaxFlo II
1helpful
The pump comes factory set for 230v. Power to the motor is 115v so I switched the jumper as indicated. The jumper is set on 2 posts with an arrow pointing to 230v. I moved it to 1 post and the arrow now...
CHECK YOUR BREAKER IT MIGHT BE THAT YOU ARE 230V .. IF IT IS A WIDE BREAKER ITS 230 OR IF IT IS A SLIM BREAKER ITS 115V , A VOLT METER IS YOUR BEST FRIEND.. REMEMBER TO VOTE FOR YOUR FAVORITE FIXIT GUY ! THANKS JAY
1helpful
I am replacing my Hayward 1 HP superpump. The old pump had the 230/115 conversion plug on line 1. The new pump has it on line 2. Do I jusst connect the 115 v(hot) wire to line 2? That would be oppisite of...
It will not matter where you put the hot and neautral as long as one goes on line 1 and the other on line 2. Just be sure to reset the voltage indicator to read the 115V like before and your all set.
3helpful
I am installing a Hayward Pool pump max flo II at 120 volt. I have 2 connections L1 and L2. Which one does the black hot wire go to.
Either one. Neutral to the other post. Be sure to set the voltage change device to 115V to match your incoming line voltage.
Need wiring diagram for Hayward dual Super 2 speed pump. Old unit had 3 wires and new unit has 5 wires.
You need 4 wires to wire the 2 speed pump. You will also need a 2 speed time clock.. Tightwatt or intermatic. The wiring diagram is on the motor.
New hayward 1 HP super pump runs 1 or 2 seconds, then shuts off. After 1 or 2 minutes, will come on for 1 or 2 seconds, then shuts off again
Check that the motor is set for the proper voltage. They are usually factory connected for 230V and if you have a 115V line feeding it the motor will overheat and cycle the overload as you describe.
1helpful
Switching my hayward pool pump from 230v to 115v. I was told i could just move the jumper, line up the arrows for 115 and be fine but my gfi keeps tripping out?
5helpful
2answers
Wire Hayward Super Pump for 115
If you look closely, you should see a small arrow on the black plastic piece on the terminal block(jumper). That arrow lines up with either the 115 or 230 mark on the white terminal board. Make sure it is aligned with the 115.
Then put you two line wires on. It does not matter which wire goes to line 1 and line 2, just be sure you DO NOT put them both on the same terminal. A plastic divider usually seperates the two line connection terminals.
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
john h
ZJ Limited
ZJ Limited
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
