Question about Electrolux EW30ES65GS 30" Slide-in Electric Range with 5 Radiant Elements, 4.2 cu. ft. Self-Cleaning... Range
My oven is beeping on an E11 error code on my electrolux range. How do I stop this?
Electrolux
  • Official Brand Answer
  • 4,342 Answers
E11 indicates a communication error where a technician needs to diagnose the control board.
Posted on Jul 25, 2012
2 Related Answers
Macmarkus
Mark MacDonald
  • 2605 Answers
SOURCE: My new Slide in electric range...I just spilled
Hello, welcome to FixYa.
I understand you have the new Electrolux/Frigidaire EW30 series slide in range, correct ? I also understand based on your post you're getting the E11 error message. According to the service manual, here's what it is and what you can do...
macmarkus_929.jpgIf you pull/slide the unit away from the wall and unplug it or turn the house breaker off for 30 seconds to a minute the control should reset.
That should do it...Let me know how you make out and if you need anything further I'll be glad to help in any manner I can. Good luck.
Regards,
Macmarkus :)
Posted on Sep 09, 2011
Anonymous
  • 251 Answers
SOURCE: How to clean lower oven of 30" electric range by electrolux
try a lemon heated and the acid will eat away the food
Posted on Dec 01, 2008
Why do I get E 21 message on my Electrolux slide in range Model EW301S6CjSc which has frozen the stove top
Thank you for your post, Sandra Gee!
Based off the information you have provided an "E21" error code is displaying on your Electrolux range. Typically, an "E21" stands for a communication failure between the EOC (Electronic Oven Control) and the ESEC (Electronic Surface Element Control). I would suggest performing a reset on your range and you can do that by disconnecting the power from it for ten minutes. The best way to disconnect power is to flip the household circuit breaker. If you continue to have an issue with an "E21" error code I would have a professional technician perform a diagnosis on your range to help repair it properly. Hope this is helpful. -Matt
Dec 25, 2014 | Electrolux Kitchen Ranges
Twice my new kenmore microwave has just started beeping with the error code E11 appearing on the screen.Have to unplug it to stop it. WHat is going on?
I think this microwave oven uses an inverter to control the power output of the magnetron. Usually the microwave will advertise this feature with a trade name like "accu-wave" or "true-power" or some similar label on the front of the microwave. Assuming that is the case here, then the E11 error means a bad inverter
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Aug 07, 2014 | Kenmore Microwave Ovens
Why is there an "E" and :"15" on my Electrolux Induction Stovetop? Originally it was beeping but then it stopped.
Good Afternoon Jane - Generally, error code E15 means that the unit is experiencing a power board failure. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Jun 25, 2013 | Electrolux Stainless Steel Induction Slide...
Electrolux range error code f10
Hello - Typically error code F10 indicates a variety of issues. The range could possibly have a runaway temp (higher than normal temps), shorted keypad, faulty EOC (Electronic Oven Control) or, display wire harness missing/not connected. Usually, these codes mean to replace the EOC. You may be able to reset the range by disconnecting the power to the unit for up to 30 seconds. This will clear most false error codes. You can disconnect power by either unplugging the unit or flipping the circuit breaker off and back on. If resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
Oct 02, 2012 | Electrolux EW30DF65GS Dual Fuel (Electric...
E15 error code
You have an error between the control board and electronic oven control. 1. Test the harness and connections from EOC connector P16 to Oven Relay Board J2. 2. Replace the Oven Relay Board. 3. Replace the EOC.
Aug 11, 2012 | Electrolux EW30ES65GS 30" Slide-in...
What does Error code E 11 mean? The counter top burners quit
Sorry to read about your problem, I hope this helps you out.
Error Code:
E11
Cause: Latch Problem Example: Will not clean Corrective Action: Replace latch in affected oven
Dec 25, 2010 | Electrolux EW30ES65GS 30" Slide-in...
Error: F 10
That model number does not seem correct but error code F10 on the Electrolux ovens relates to a faulty power board.If that Serial is correct then it is still covered in the 12 months full warranty.
Hope that helps.
May 11, 2010 | Electrolux ICON Designer E30SO75ESS Oven
I tried cleaning the oven and got the error F3.
Electronic control has detected a fault condition. Push CANCEL pad to clear the
display and stop the display from beeping. Reprogram the oven. If a fault reoccurs,
record the fault number.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 13, 2009 | Electrolux Kitchen Ranges
Troubleshooting range
f1 code relates to a problem with the electronic oven control, no fixing the part only option is to replace it
Feb 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Electrolux EW30ES65GS 30" Slide-in Electric Range with 5 Radiant Elements, 4.2 cu. ft. Self-Cleaning... Range Logo
7,706 people viewed this question
Top Electrolux Kitchen Ranges Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Andrew Taylor
Andrew Taylor
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
