Answering Line 2 today has resulted in every call being full of static. So much so that I can't hear the person on the line. At first I thought it was a specific area code, but it's every call we receive. None of the other lines are static-y.
SOURCE: I would like Line 6 on Norstar System to Ring Different
Normal
0
To Change your Ring Type:
1. Press the Feature button, then * 6
2. Press the number keys 1 – 4 to hear the different ring types
3. Press the OK softkey when you hear your desired ring
SOURCE: Norstar m7324 - forward to outside line
The solution for someone using the administrator phone (receptionist phone) is after discovering you have a fax call, depress the <link> button. Dial the fax number, wait for it to answer, then depress <link> again. This places call 1 with an outside number.
Apparently this is also available if you have a feature button by depressing <feature> <7> <1> instead of <link>. I haven't tried this so don't take my word for it.
This can also be used to forward a caller to an outside line, such as a cell phone. In the manufacturing business, our shop manager is never in the office. I may ask him if this is a viable solution.
SOURCE: answering call
Feature ** 266344 password 266344 (assuming the default passwords are set)
A. Configuration
2. Line Access
Show set (enter the telephone extension set number that needs to be changed) ex 34
Then press enter 4 times until you see the 'Prime Line'
Press the change button to set the desired line that will activate when the handset is picked up.
(It will probably display 'None' at present before change)
Press enter and release.
SOURCE: Norstar 7324-two lines show in use, but wont hang up
Power cycle the system. You need to go into lines/trunks and change the line typ from unsupervised to supervised so this will stop.
