Question about Rheem Heating & Cooling
RHEEM ELECTRIC FURNACE STOPPED WORKING
Model# aof 14f 201
1 Related Answer
Donni Steen
  • 687 Answers
SOURCE: My (Rheem)electrical heater is not heating the
Check all your manual reset limits. There are two wires that go to a small disk about the size of a penny. In between those wires is a small button. Press the button firmly. You will have between 2 to 5 of these. There is also a limit switch located on the back wall of the unit that enters in the heat exchanger but it is not resetable that could be bad. You will need to check all of these. They can be jumped temporarily by removing the wires and adding a small wire.
Posted on Apr 06, 2009
Ever limit switch i changed in my Weatherking furnace, it breaks the switch, what could cause this?
You need the model number of the furnace to determine what the flashing light is telling you. Many times the part that looks to be at fault is not the true fault in the furnace. A slow running blower could cause the limit switch to trip. The circuit board tells you that the limit tripped, but the real cause is the motor or clogged filter.
Jan 02, 2016 | FACTORY AC PARTS Limit Switch Double Pole...
LX2000 gas furnace. It starts and runs for about 5 seconds, then why does it shut off?
Fix Furnace Flame Sensor (Flame That Goes Off) - YouTube
? 1:22
https://www.youtube.com/watch?v=fBJ3r9MUa-U
Nov 29, 2011 - Uploaded by RochNoure
A Furnace Flame Sensor is a safety device that reads the temperature and ... easy fix, but the furnace is ...
Troubleshoot the ignitor of the Rheem RGDA model gas ...
? 5:53
https://www.youtube.com/watch?v=Bx1pXONg2Oc
Dec 12, 2012 - Uploaded by grayfurnaceman
Troubleshoot the ignitor of the Rheem RGDA model gas furnace.... Jun Sim 5 months ago ... My lennox ...Missing: lx2000
Rheem Criterion II No Heat - YouTube
? 0:47
https://www.youtube.com/watch?v=yOSk6qvpWbA
Jan 7, 2010 - Uploaded by Work12Progress
Rheem Criterion II gas furnace model # RGPH-07EAMGR. When a call for heat is made t wo green led's ...Missing: lx2000
Heater will not kick on unless... [Archive] - Self Help Forums
www.selfhelpforums.com/archive/index.php/t-2153.html
Oct 19, 2004 - 25 posts - ‎9 authors
After a certain amount of time of not running, the heater will refuse to kick back on. ... 2 flashes, then a 2 second pause = pressure switch is open. What do .... On LP gas furnaces, the spark starts and the gas valve opens. ... Buffing them up with a little steel wool (5 minute job) is a good annual PM thing to do.
Dec 16, 2015 | Heating & Cooling
My white-rodgers1c20-201 thermostat just stopped working,what could be the problem
That unit is a 24 volt snap in model. The unit is not made anymore. You can use a meter to check the transformer for it. That transformer is located on or near the furnace. It can also be the fuse. I would recommend that you replace it.
Oct 11, 2015 | Heating & Cooling
Why is my 95% rheem furnace blinking code 2
Check condensate water /drain stopped up. It will allow a start after a reset but then it shuts the combustion air fan down and that shuts the unit down this will require a service tech make sure their familiar
with 95% units
Oct 19, 2012 | Rheem Gas Furnace 60000 Btu 95% Afue. Rgrc...
Will not heat we replaced both elements but still no hot water rheem model no.82v522marlene we suspect we had a power surge during last storm because the furnace went out also at the same time
Hi I suspect your thermostat will have also been damaged if you had a surge I always replace thermostats at the same time as the elements
Also check the wiring as sometimes surges can melt the copper core of the wiring, but be careful always turn off the power first before any electrical works!
Mar 06, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Rheem RBHC-17J14SFA elec furnace fan won't stop
sonds like u have a bad safety switch they r round and have 2 wires on them usually and u can check them by taking the wires off of them and checking continuity thru them there might be one on the blower housing also either that or ur blower relay may be bad and stuck closed
Feb 18, 2010 | Heating & Cooling
RHEEM OIL FURNACE MODEL ROBD 067 LBEA BLOWER
You will likely need to install an isolation relay in the W circuit from the thermostat. Some thermostats rob a small current through the W circuit to power the thermostat. This small current can be enough to start the fan circuit timer. You can test this by disconnecting W at the furnace and allowing the timer to shut down. If the fan shuts off with the W disconnected you can install a simple relay.
The relay coil will be connected to Common on one side and the W from the thermostat to the other. Then you will run a wire from R on the furnace to the relay and from the N.O. Contacts to the W terminal on the furnace. This will kill that signal that is starting the timer and the W can steal it's power through the coil back to common.
Dec 23, 2009 | Honeywell Electronic Programmable...
How can I get a manual for my Rheem Gas Furnace
Contact Paloma/Rheem customer (800-432-8373) support and tell them what you have; they'll send you the documentation - by regular/email.
Happy Holidays;]
JZ...
Nov 25, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Trouble shooting manual for Model# RGUJ-05EA-ER RHEEM GAS FURNACE
replace the gas valve....test for 24volt at the gas valve input.  if you have this then it's a def gas valve relay not working.
Dec 09, 2008 | Heating & Cooling
Heating & Cooling Logo
140 people viewed this question
Top Rheem Heating & Cooling Experts
Lawrence Oravetz
ray gallant
 Russ Hill
Russ Hill
Are you a Rheem Heating and Cooling Expert? Answer questions, earn points and help others
