Question about Acme 5001 Supreme Juicerator Juice Extractor
Opening lid to add fruits
How to open lid to add fruits or vegetables??
Posted by Rosenn on
Lance Hill
    Genius:
  • 1,739 Answers
The Manual for the Acme 5001 Supreme Juicerator can be downloaded from the following link:
http://www.everythingkitchens.com/PDFfiles/6001.pdf
Items to be juiced must be cut to size and fed through the feed chute. The machine will not operate if the cover is not properly in place.
Posted on Jul 24, 2012
BADLY SQUEEZES OUT VEGETABLES
Search Results
    45 Uses For Lemons That Will Blow Your Socks Off
    preventdisease.com/.../052713_45-Uses-For-Lemons-That-Will-Blow-Y...
    May 27, 2013 - You can make sure the white vegetables stay white by squeezing a teaspoon ... Slice your lemon and squeeze out one tablespoon of lemon juice into ... alters the pH level in your mouth, killing bacteria that causes bad breath.
    Bad news for vegetarians! Plants can 'hear ... - Daily Mail
    www.dailymail.co.uk/.../Bad-news-vegetarians-Plants-hear-eat...
    Daily MailJul 2, 2014 - Researchers in Bonn, Germany, found plants give off a gas when under 'attack'. ... The research could help to work out which pieces of fruit and vegetables ..... creates YouTube channel dedicated to spot squeezing - and her.
    The GP who gave up fruit and veg to cure her aches and ...
    www.dailymail.co.uk/.../The-GP-gave-fruit-veg-cure-aches-pa...
    Daily MailJul 16, 2012 - I slept badly - I suffered from restless legs and my muscles kept ... cutting out virtually all 'healthy' food - I avoided most fruits and vegetables, salads, ..... in a series of sold-out seasonal shows; Casey Batchelor squeezes her ...
    Market Dis. of Fruits and Vegetables: Citrus and Other
Dec 16, 2015 | Juicers
Wwwprodprotectcom applica
No not if they are organic. Much of the goodness lies just below or in the skin. Much non organic fruit and veg though is chemically sprayed so better to remove those.
Mar 26, 2014 | Applica Black & Decker JE2200B Fruit and...
I have lost the jug bin of my juicer (where the fruit pulp goes) and am no longer able to use the product as I get waste every where. Could someone tell me where to get a new one from? I have a JE95B...
I really have no idea where to find a new one, but... I've got Jack Lalenne's Power Juicer, an older model, and I, too, have lost the jug bin. So, what I do, is use a plastic bag. I pull it over the whole opening through which the pulp comes out and add some scotch tape so it doesn't fall off. I'm pretty sure a paper bag could be used, as well. I know it doesn't answer your question, but it can be a temporary solution..!
Sep 05, 2011 | Juicers
After juicing just a few fruits and vegetables the machine start jumping all over the counter and vibrating really fast.
There is no solution. These juicers do not eject the pulp and go out of balance very easily.
Don't feel bad, I've seen you tube videos where the demonstrator couldn't keep it under
control. If you are unable to master it, consider a pulp ejecting or masticating type juicer.
Mar 08, 2011 | Omega 1000 Juice Extractor
I HAVE AN OLDER KRUPS JUICER TYPE 251. IT SAYS IT IS MADE IN SWITZERLAND. THE METAL HANDLE WHICH KEEPS THE TOP ON TIGHT IS LOOSE. THE SPRING HAS FALLEN INTO THE BOTTOM OF THE HOUSING. THIS MEANS IT CANNOT...
Did you ever find a manual? I have the same machine, working fine but I'd like to know if I should use the plastic strainer for all my juicing or just for certain fruits or vegetables.
Jul 18, 2010 | Krups Juice Extractor
Manual for the black & decker juicer
It's here. Thanks for using Fixya!
Feb 25, 2010 | Juicers
How do you take the grater off the juiceman2 the part that the fruits and vegetables get grated. Thank you
how do you take the grater off the juiceman2 the part that the fruits and vegetables get grated.
Dec 12, 2009 | Salton JM411 Juiceman II Elite Juicer
Sometimes it will spin out of control the lid pops off and its scary! This seems to happen when I juice cucumbers even though I take the seeds out. Yesterday I juiced lettuce leaves, celery (2 sticks),...
DROP THE FILTERS. FRUITS AND VEGETABLES HAVE TO BE FED SLOW
AND STEADY. IF THE JUICER IS OLD THE
GAP BETWEEN BLADE AND CHUTE MAY
BE TO WIDE LETTING LARGER PIECES
THRU AND THROWING IT OUT OF
BALANCE. USING ONE FOR 19 YEARS
AND THEY ARE TRICKY.
Jul 16, 2009 | Acme 5001 Supreme Juicerator Juice...
No way to send the fruits & vegetables through:/
1-800-233-9054, or online at foxinternational.com if you are in the U.S.A. I am pretty certain they will have it. I lost mine--& use a long carrot to push whatever through. If some of the carrot gets juiced--no problem. It is good for you, & tasted great!
Oct 21, 2007 | Juicelady JL500 Juice Extractor
Acme 5001 Supreme Juicerator Juice Extractor Logo
230 people viewed this question
Top Acme Juicers Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you an Acme Juicer Expert? Answer questions, earn points and help others
