SOURCE: noisy drum
You may have a rear drum support issue. There are 2 rollers,(supports), 1 at 4 o'clock and 1 at 7 o'clock. If the bushing in the roller becomes elongated,(elliptical), it will give a thumping noise, as you describe.
Below is a link with exploded diagrams and parts help.
http://www.repairclinic.com/0100_14.asp
Please rate my answer on how helpful it was in resolving your issue.
Thank you,
Dave E. (Illeagle)
SOURCE: WHIRLPOOL GAS DRYER MODEL LGQ9030PQ1 DRYER RUNS BUT NO HEAT
First, as a retired Fire Captain I must recommend turning off all running appliance before leaving the house or going to bed. I can tell you some real horror stories. Now, there are several parts that can keep the heat off or flame off and they all need to be checked with an OHM meter. It could be the ignitor, ingitor sensor, or gas solenoids. Get a service tech out to check which you need or if you have an OHM meter I can give more info on what to check.
SOURCE: Whirlpool gas dryer model#LG5791XM- the burner is working off&on
first check to make sure the venting isn't blocked by lint. second, check the igniter, if it is orange in color you need to replace it, it should glow white.
SOURCE: Gas Dryer no longer putting out heat.
Hi, If you have a gas dryer.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting Electric Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Testimonial: "Thank you so much for that information! I will have my neighbor take a look at it today and let you know if it was indeed the ignitor. So helpful!"
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
