Bunn BT10B Coffee Maker Logo
Shawn Rick Posted on Jul 23, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water leaks - Bunn BT10B Coffee Maker
Phillip Hicks
Level 3:
  • Master 917 Answers
  • Posted on Jul 23, 2012
Phillip Hicks
Master
Level 3:
Answers
917
Questions
0
Helped
162463
Points
2822
You don't state where water leaks from, 2 solutions, tighten up connectors, or fit new " O " Rings to the connector pipes.
2answers
Why is oil leaking from where the water pump bolts to the engine on my generac pressure washer model 01676?
front seal, leaking oil means there is less oil in engine. continue and you will a new engine, have it repaired quickly.
Why does my samsung fridge leak water under the fridge when I use my water dispensor?
hi Todd.
Problem: It's leaking water. ... Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leakingout of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself - CNET
https://www.cnet.com/.../three-common-refrigerator-problems-you-can-easily-fix-yourse...
Why is my refrigerator leaking water from the bottom?If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.17 May 2013SOLVED: Water leak in refrigerator? - Refrigerator - iFixithttps://www.ifixit.com/Answers/View/128713/Water+leak+in+refrigeratorSearch for: Why is my refrigerator leaking water from the bottom?
Why does samsung fridge leak water under the fridge Google Search
2answers
I have a 2013 keystone cougar 327res and the belly pan is full of water...where should i look for my leak?
This is not just for your camper, but general troubleshooting.
Drain the water from the belly pan. Hook up water supply to shore water source. With water source turned on, allow some time, 1-4 hours, and check if water has returned to belly pan. If water is present then the problem is with the fresh water system. If no water, either it is a small/slow leak or the problem is not with the fresh water system. Next test the grey water tank by pouring some red food color into the shower or sink drain. Flush it into tank with water. Again, wait for some time, maybe over night, and then check for red water in the belly pan. It may take longer for the leak to appear as the grey water tank does not have pressure. If no water, check the black water tank with green food coloring and same technique. If there is colored water, red or green, in the belly pan, then the leak is with associated with the grey or black water tanks. If no water is present after these tests, then the leak may be very small and it may take days or weeks to have water re-appear. In any event, clear water is fresh water system, red water is grey water system, and green water is black water system. With any of them, checking the tanks themselves and all pipes and connectors to/from should find the leak source. The last possibility is that water is entering the belly pan from a roof or vent leak. Check to see if water returns to belly pan after a good rain. If so, the water may be clear or slightly dirty. If it is a roof leak, I have found the best repair is to use Peel and Seal roll roofing It is light weight laminated aluminum and self sticking. Cutting and applying narrow strips 4-6" wide, will seal any caulked area. It costs $95 (3' x 33') at Lowes. A 30" motor home can be completely covered with three (3) rolls, in half a day. I have re-topped 5 motor homes (one 7 years ago) and no more leaks on any of them. The product was developed to seal the roofing joints of mobile homes. Topping should last 15+ years.
1helpful
5answers
Repair a cold water leak at the bottom of my water heater
Hi -
If your water heater is working (ie: making hot water) then most likely your heater isn't leaking. Rather, the leak is coming from the cold water supply and running down the tank where you see it at the bottom of the tank. A working tank that is leaking would produce a leak of hot water - not cold. You should carefully check the cold water piping for a leak, drip or stream of water and make the required repairs.
Ge smart water heater
Depends on source of leak:
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
http://waterheatertimer.org/Leaking-water-heater.html
Some leaks can be repaired, while other leaks indicate that tank is rusted and needs replacement.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
Hot water heater has a leak somewhere but not at top where water hoses connected
Leaking water heater because steel tank wall rusted through
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Is this gas or electric?
Element leaking on electric heater?
Came down stairs water heater off and pan filled with water
Copy following link for troubleshooting leaking water heater.
You posted question under propane gas heater.
Propane is heavier and air, and this type gas water heater should not be installed in basement (below grade) since gas leak can fill basement with explosive gas.
Water leak does not cause gas leak, so water leak is separate problem.
Recommended for propane safety: install gas detector close to floor near gas water heater
Regular Natural Gas heater, install gas detector higher on wall since NG is lighter than air and will rise.
3answers
RHEEM 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF: water leaking from top of water heater how can i f...
If water is leaking from a pipe. then replace or repair the pipe or fitting. If the leak is coming from the unit itself, then replace the unit. Hope this helps.
Top Bunn Coffee Makers & Espresso Machines Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
