Question about Samson XP40iw Speaker PA System
How to fix a Samson XP40iw Speaker PA System
It does not sound, has a full battery charge, the red bulb at the back blinks only when the sound level is way up. but no sound comes out. It was working great until a week ago. What can that be?
Posted by EHR1960 on
Mark Yount
    Problem Solver:
  • 7 Answers
Have you checked the cables? If that doesn't fix it, you probably have a loose connection inside between the "mixer" unit and "amp" unit
Posted on Jul 25, 2012
  • EHR1960 Jul 28, 2012
    Mark, thanks a lot will open the speaker in the backa and check for any loose connections. Will let you know
Battery not holding charge on Alesis transactive pa system. Power cord connected and keeps turning off.
If the battery is old, say three years, it may be worn out. Fully discharging batteries or using them beyond where they have noticeable loss of power results in reverse charging the weakest cell which then often shorts rendering the battery un-rechargeable.
Aug 01, 2011 | Alesis TransActive Mobile Speaker PA...
Hi, I have one Samson Auro d412a active speaker plugged into the output channel of a 12 channel passive mixing board. When I sing into the mic, the speaker shuts down and the red light on the back...
If you read the TRUE specs on this speaker it is really a 200 Watt RMS unit. Make sure you are using balanced lines to the speaker XLR or TRS cables. The mixer should NOT be a passive mixer as these do NOT generate true balanced lines. Make sure the mic can't "hear" the speaker or you may be getting supersonic feedback that is above your hearing range that saturates the amp. If *********** can't stand to be ain a 15 foot square room with teh level you are generating, it is TOO loud for this unit to handle.
Aug 01, 2011 | Samson Auro D412A Speaker PA Active
Have a problem with the xp510i - left channel has no output to speaker. Tested with other speaker and cable - appears to be the mixer.
"Tested with other speaker and cable" ... you did not tell us the results of the test. If swapping the speakers and cablles still had the same dead side, it is probably the power amp for that side and not the mixer part. Take in for repair. If you had an accident of speaker cable not being plugged in fully or pulled out while operating, this pops the power amp real quick. They also just plain fail at times. Plug a set of headphones into the MONO out jack. If you can hear audio going through the unit then the mixer is OK... and the power amp on the failing side has a failure. Note the headphones will be low level and probably only one side, usually the left as this is a mono signal and headphones are normally stereo.
Apr 26, 2011 | Samson EXpedition 510i Speaker PA System
What do I need to hook up to our church pa system
Connection all depends on what type PA system you have. Here are the rules: Power this device from the SAME receptacle your mixer is powered by, even if it means running an extension cord. Use ONLY a balanced line from the mixer... either TRS cable or XLR cable.
Apr 02, 2011 | Samson Auro D412A Speaker PA Active
Samson XP40iw Speaker PA System Logo
1,079 people viewed this question
Top Samson Music Experts
Lawrence Oravetz
Vernon Taylor
rhodesworks
Are you a Samson Music Expert? Answer questions, earn points and help others
