2006 Kia Sedona 2.9 Logo
Gavin Posted on Jul 23, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SWAPPING REAR SEATS AND MIDDLE ROW
CAN YOU CONVERT RUNNERS ON MIDDLE ROW TO TAKE THE REAR SEATS OF A SEDONA 2006?
Marvin
Level 3:
Top Expert:
  • Kia Master 85,242 Answers
  • Posted on Jul 23, 2012
Marvin
Kia Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29028325
Points
266281
This type of modification is not recommended due to the structural limitations involved. In short it is unsafe to modify a car this may in case of a crash,.
1 Related Answer
Anonymous
  • 4803 Answers
  • Posted on Apr 24, 2011
SOURCE: I have a KIA Sedona LS 2003. I cannot remove any
The rear seat removal is covered in the owner's manual on page 3-25.
Here is a direct link to download a PDF Version of the owner's manual.
2003 Kia Sedona Owner's Manual
2006 Pontiac Montana. Can I remove 1 of the middle seats?
Question edited for clarity.
Question moved to model category.
Air bags only deploy if there is weight on the seat. Yes they are removable.
Pontiac Montana SV6: how to remove second row seats ...
JustAnswer https://www.justanswer.com > Pontiac Problems
Apr 21, 2015 - HI, Attached at bottom of the answer is directions to remove the seats - below is procedure to disable airbags before beginning work ...
1 answer · Top answer: HI, You can but you have to know the resistance of the airbags, which unfortunately gm doesnt ...
Removing The Bucket Seats - Pontiac Montana SV6 2008 ...
ManualsLib https://www.manualslib.com > ... > Owner's manual
1. Pull the nylon strap or lift the recline lever. · 2. Press back on the seatback until it is in the desired. position · 3. Let go of the strap or lever.
Removing Third Row Seat From A Pontiac Montana An Easy ...
osvehicle.com https://www.osvehicle.com > removing-third-row-seat-...
Mar 29, 2023 - The most straightforward way to move the furthest back seat is to remove it from the back door and slide it out. Uncomplicate The Task: Removing ...
I cannot for the life of me figure out how to fold up my second row seats in my 2014 kia sedona. I read the manual and I still can't get it to fold up. Can you help explain how to do it?
Slide the seat back as far as it will go then release the lever on the side and it will flip up, fold and lay flat to gain acces into rear seats!
I have 2 bucket seats in the middle of my 2007 montana. can i take one out?
Yes of course you can remove the seat. There is a pull at the rear of the seat in the middle (down on the frame) The pull is a loop of material. You need to pull that up with solid force, this will release the lock so you can tilt your seat forwards. Once the seat is rotated forward enough, you will be able to lift the seat out.
I leave my seat out behind the drivers seat most of the time for easy access into the back and just putting stuff in the car. Also, the side clearance height is higher than the rear hatch height.
1helpful
Removing 2006 kia sedona captain seats
Ditto for me. My son accidently latched one of the rear latches but none of the others. We could not get it off. We found this answer and tried it and it worked. I lifted on the rear of the seat while he folded the back of the seat down. It released when we did this. Whew
Can I convert my 2nd row seating from two bucket seats to a 3 seater bench in my 2009 Kia Sedona?
Did you ever find a solution to this problem? I too am looking to convert to bench seat in middle row
1helpful
I have a old mercury villager ...i want to replace the middle row seat with last row seat ...is it posible...?
The middle row seat slides forward to the middle position (and several other positions as well.)
Owners manual explains how to slide rear seat foreard.
Remove middle row seats. Lift handle under 3rd row seat cushion on passenger side. Raise seat cushion up until it locks up. Then lift the lever on the passenger side of seat and pull seat forward until it locks in place.
if you don't have owner manual, go to motorcraft.com, pro center, tech info, owner manual.
join our group for free help.
please rate too. Thanks.
http://groups.yahoo.com/group/villagerquest/
How do you remove the 2 sliding rear seats in a gmc acadia
On the front corner of your Acadia's middle row seats, you will notice a plastic covering - pull on it - the plastic pin holding it back will fall off, and you can then remove it. Now, the bolts that need to be removed to unmount the seat, are clearly visible.
Also, experts recommend that it would be best if the doors are removed to give enough space to manage the task. Removing the doors may take you about 10 to 15 minutes, whereas seat removal can take 20 to 25 minutes.
Middle row back seats...how can I remove or collapse them, I know back seats fold completely to floor, but what about middle row?
first fold them flat then pull the handle which will release the rear bottom brackets and allow you to pull back and lift the entire seat out of the van....both seats.
9helpful
2answers
I want to make my 1999 Mercury Villager Sport into a cargo loader, with just the front seats kept and the rest of the back empty. How do I remove the other 3 seats? So far, I can't get any of them to budge...
the middle seats come out easily. There are 2 handles you have to lift up on each of the bucket seats, they are in the front of the seat down by the seat tracks. After you lift them, tilt the seat upward in the front and rotate them backward. Then lift out of the hooks. Each seat is held down by 4 hoks.
The 3rd row seat is not designed to come out xcept by a technician. It does slide forward all the way up to the front seat. It has a sliding seat track.
First, lift the T handle under the seat cushion on the left front side of the seat. This will allow you to lift the seat bottom up all the way to lcok in the full up position.
Then, lift the lever on the same side of the seat and slide the seat forward. It will stop in 4 places.
Rear -Rear
6 inches forward of that.
another two ft to the second row seating position
full frward against the front seats.
Pleae rate as fixya if this helps.
c4253aa.gif Seat —Third Row Bench Removal
sxv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Removal of the third row bench seat requires more than one technician.
  1. Remove the second row seats. For additional information, refer to Seat—Second Row .
  1. Remove the floor mats.
  1. Lock the seat cushion in the upright position.
    1. Lift the handle to release the cushion.
  1. Move the third row bench seat to the second row position.
    • Lift the seat track release handle.
  1. Remove the two bolt covers.
  1. Remove the two seat track front bolts.
  1. Remove the four seat track rear bolts.
    1. Position the rear seat cushion floor cover aside.
  1. Remove the third row bench seat.
Top Kia Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Kia Expert? Answer questions, earn points and help others
