Kaz 4100 1 Gallon Humidifier Logo
Thea Van Zyl Posted on Jul 23, 2012
How to take apart a KAZ4100 humidifier - Kaz 4100 1 Gallon Humidifier
2helpful
My humidifier is not working. It is on but the light is orange instead of green. No mist is coming out.
There is probably a calcium buildup in the lines from the tank to the humidifier. You will need to take it apart to lean it. 50/50 White Vinegar should do the trick, Then flush the system with clean water, before using it as a humidifier again. In the future try using Bottled Spring Water or Distilled Water instead of tap water. Especially if your source of water is a well.
Water is not flowing. I took apart the control cylinder and reattached it to no success.
Seloniod water valve orifice may be clogged (very small opening). Try removing it and cleaing the nozzle with a toothpick.
How do i take apart and clean my Vicks V3100 cold air humidifier?
couple of screws on the bottom, but why take it all apart when you can probably run vinegar through it and let that do the work, smells a little, so maybe on the porch...
2answers
The humidifier is only a month old, but it is making a loud rattling noise
take the tank off and the fan unit housing. inside you'll see a circular filter that goes into the water sump. make sure it isn't falling apart and hitting the fan blades.
1helpful
How do I take the hose apart to clean it because it has mold in it?
just replace the hose. its 1/2 vinyl tubing you can get the required length at any hardware store and a hose clamp to support to bottom of he humidifier
2answers
Humidifiter doesn't humidify
have you checked the misting nozzle? if its clogged place it in (CLR) and let soak, I would try to run a little diluted (CLR) through the unit as well, to remove any calcium build up, that is the most common problem with most humidifiers, also check to make sure the pump is working, if not you will need to replace the pump, hope that helped
1helpful
2answers
Reset light on holmes product hls5000 humidifier
turn knob to reset....leave 15 minutes and then turn on
Top Kaz Humidifiers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Kaz Humidifier Expert? Answer questions, earn points and help others
