Question about Integra Dtr-20.3 THX Select2 Plus AV Receiver
Integra dtr 20.3
Hdmi over Bakunin comes and goes but after a firmware update the problem went away. Next day the problem returned. Is thre an internal battery inside that may be replaced
2 Related Answers
Anonymous
  • 33 Answers
SOURCE: I have an integra dtr 7.7 receiver which when
obviously a short somewhere in the system....
you know what i would do?
pray to god you are still under warranty! XD
its a beautiful machine....
Posted on Jan 08, 2010
Anonymous
SOURCE: the reciver dosnt get a signal from the hdmi
HAVING THE SAME PROBLEM. omg. maybe there is help. will get audio but no video from DPS dvd player and PS3. no onscreen menu either. changed hdmi cord. seems to be problem with reciever. DVD works fine when changing to component cables instead of the HDMI. sometimes plugging and unplugging the HDMI cable gets the PS3 working. Don't quite understand scrap605's suggestion. but that doesn't solve this prob.
Posted on Mar 07, 2010
I am not getting any audio (sound) out of my Integra DTR 4.6. Any suggestions?
Does the vu meter show anything(bars moving up and down when audio is present?If so you may have a blown fuse or bad IC in the amplifier section causing the problem. If there is no indication of audio on the front panel it would be a Microprocessor problem
Oct 15, 2014 | RCA Onkyo Integra Dtr-4.6 Av Receiver Wrat
How do I get into the network and firmware menu?
Try the following
Via Net
Is it reasonable to assume your router requires password / ssid to secure internet access ?
Due to age of this device,
(1) Lower / disable current router security settings
OR
(2) connect device directly to modem. ( softest, easiest way )
This may require you to disconnect modem from router, reset your modem then connect cable direct between modem and DTR 40.1 device.
When completed, the Modem ( and Router ) may need be reset, prior to re-connecting network
Firmware update information link ( from manual )
http://filedepot.onkyousa.com/Files/own_manuals/Firmware_Update_for_the_DTR50_1_40_1_DHC40_1_100110.pdf
Step 3:
Go to "7-6. Firmware Update" menu.
Note that the Firmware Update option will be grayed out
for 30 seconds after AV receiver/controller is turned on.
Please wait
( system attempts internet link for approximately 30 seconds ? )
Not outputting Sound ( trouble shooting ) link
http://www.integrahometheater.com/faqs_detail.cfm?detail=1&id=347
Hope this was helpful
May 12, 2014 | Integra Thx Dtr 40.1 Receiver
"handshake" between DTR 5.9 and an LG Blu-ray player
You will have a defective processor pcb. You may want to see if you can get Integra to give you a one time repair on this.
Mar 26, 2014 | Integra Onkyo Rc-711m Dtr-4.9 / 5.9...
Integra DTR-5.6, no sound for am/fm tuner
reset receiver if that does not work You will have a defective processor pcb
Aug 24, 2013 | Integra DTR 5.6 Multi Media Amp
How do I set up an Integra DTR 7.8 for 3D display and audio
Your DTR-7.8 receiver is not 3D compatible. It does not support the new 1.4 HDMI. You have to have 1.4 HDMI and 1.4 cables for the 3D format.
You can bypass your receiver for the video though. Simply run your HDMI cord (1.4) from your Blue Ray to your Projector. Your audio can be ran from your Blue ray to your reciever.
May 17, 2012 | Integra Audio Players & Recorders
The reciver dosnt get a signal from the hdmi inputs both ps3 and blu ray have the same problem it is a dtr 5.9 integra
what you should do is make sure that your HDMI is cord is not in an awkard position, which like mine i have to unplug and plug back in to get a signal
Mar 01, 2010 | Integra DTR-5.1 Receiver
Sansa E700kepts re-setting
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Dec 21, 2008 | SanDisk Sansa e200 MP3 Player
My Samsung LN40A530 only produces a blank blue screen whenever I try to use an HDMI input source. Audio seem to come through fine but not the video. Other, non-HDMI video inputs work fine. I've tried...
We are having the same problem. We have 2 DVD players with up-converter to 1080i and 1080p. Both DVD work fine (one Sony and one Samsung) with our Samsung LN-T4053H upstairs, never intermittent.
LN40A530 downstairs is having "Searching for Signal" problem. Took it back to Sears got a new one, problem followed. Something is wrong with this LN40A530. Perhaps firmware update is needed.
Jun 11, 2008 | Televison & Video
Volume control unstable
You may have an over heating problem as it the Integra has anautomatic cut out. The unit generates a huge amount of heat and needs to be positioned in a very well ventilated position.
Linian
Dec 11, 2007 | Integra DTR-5.1 Receiver
Integra Dtr-20.3 THX Select2 Plus AV Receiver Logo
67 people viewed this question
Top Integra Audio Players & Recorders Experts
Andrew Taylor
Andrew Taylor
Larry Stiles
Larry Stiles
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
