Question about Insignia Televison & Video
How to program a new tv to remote - Insignia Televison & Video
Posted by Terry Myers on
    Top Expert:
  • Insignia Master
  • 76,416 Answers
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Posted on Jul 23, 2012
Need sansui 076k0ut011 led tv remote codes to program an rca tv
reset sansui tv remote control 076k0ut011 Questions ... - Fixya
www.fixya.com > Forum > Tags
...your help in advance. need code for a one for all URC-2060B06 sansui tv try these ... ...sansui tv with a RCA 704 remote control I have sansui tv and a RCA 704 remote ... URC-3021 Remote Control: How do i program this remote to a sansui tv? ... TV Remote Controls Sansui Remote eBay NEW Orion Sansui JVC LED TV ...
reset sansui tv remote control 076k0ut011 Flat Panel ... - Fixya
www.fixya.com > ... > Tags > reset sansui tv remote control 076k0ut011
Flat Panel Televisions reset sansui tv remote control 076k0ut011 questions and answers. ... ...sansui tv to program rca remote to it model # HDLCD1955C need tv code for this model ... Question about Contex 39-inch 1080p LED TV LE39D3.
Original Sansui - Orion TV Remote Control 076K0UT011 ...
? 1:00
https://www.youtube.com/watch?v=mPbRsUI0xnk
Dec 21, 2012 - Uploaded by ElectronicAdventure
Original Sansui - Orion TV Remote Control 076K0UT011 - Save $5 with ... have the New Original Remote ...
[PDF]Operating Instructions For 4-Function Cable
Dec 16, 2015 | RCA Televison & Video
My new remote that came with the tv does not allow me to change channels, but my dish remote still allows me to change channels
Your dish remote is the only one that is compatible with the dish receiver. You're going to have to program all the functions you want to use to the dish remote. They are usually set up for all the normal functions, volume, power, dvr etc.
Dec 08, 2010 | Element Electronics PLX4202B 42 in. Plasma...
I got a new tv and i would like to program my dish remote to my new tv
henneym
I have provided a link with the instructions on programming your remote to your TV. I have also included a link with the codes for each TV manufacturer. I hope this helps.
Instructions for programming remote to TV:
http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml
Ray Calo
DISH Network
Nov 08, 2010 | DISH Network IR Remote Control
Need to program new remote 3.2IR
In your Dish Network instructions it will show you how to program your TV to the Remote
Apr 02, 2010 | DISH Network IR Remote Control
Need program advice for philips direct tv 2585/01 remote
http://www.directv.com/learn/pdf/System_Manuals/Philips/Philips_DSX-5150_5353_5375.pdf
only one i found but they all seem to work the same.
Oct 24, 2009 | Philips Televison & Video
Program remote for sony ht-5100-d
Use your Directv remote. Use code 10812, remember to program it to change tv inputs also. then program the same remote to control volume on your Sony receiver. Go to the menu on the directv box and follow the onscreen instructions.
Apr 24, 2009 | Sony HT-5100D System
How do i program my remote
Hold button down for unit you want to program. (TV,DVD,VCR) Then hold down on off button at same time. On/off button will turn off then come back on. When this happens push the play button. Wait 10 seconds and then push again. Repeat until unit turns off. Once unit turns off push rewind button one at a time until unit turns back on then push the stop button.
Sep 29, 2007 | RCA RCR311B Remote Control
Televison & Video Logo
171 people viewed this question
Top Insignia Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
