Question about Razor USA Razor Dune Buggy
Razor Dune Buggy Problem
Our Razor Dune Buggy is having an issue. It says that the battery if fully charged and when the thumb tab throttle is pressed just a little it runs very slowly. As soon as the throttle is pressed more it stops running. The closest repair shop is about hour and a half away, and if someone has an idea what could be wrong with it I could buy the part myself and replace it. Please help!
Posted by aleksfrye on
shelley_mccu
I have the same issue with mine. Batterys check out fine.. i'm starting to suspect the motor??
Posted on Aug 18, 2012
I have a 650 razor motorcycle the battery shows fully charged but clicks when I turn throttle but it does runnsometimes
Hello
Before you change the battery check thoroughly all wires and all connections!!!!
Nov 26, 2017 | Razor Toys
Razor mx350
Have you tried removing plastic chain guard and making sure chain is not off track i had this problem and that is all it was.
Apr 24, 2014 | Razor MX350 DIRT ROCKET - BLUE
My razor dune buggy won't drive
are you sure that the charger is putting out enough volts to charge the batteries? check the charger with a multimeter, then check the batteries with a multimeter, and viually inspect the batteries for bulging
Apr 28, 2012 | Razor Dune Runner 350 Go Cart
My son's ground force drifter is showing a charged battery but will not go. I see the full charge lights on the throttle but it when i depress the throttle, it does don't move. Anythought? Thanks
If the battery is gone(bad), sometimes it will show fully charged (volts are good).. but it has no amperage to "push" the voltage... It takes amperage to make the drifter move... (time for a new battery)... they don't last long...
Aug 03, 2011 | Razor USA Razor Ground Force Drifter Go...
Philishave8890 when the razor states fully
It sounds like the battery pack needs replaced. You will find the correct battery type at shaveroutlet.com. See link below. You will need to order 2 batteries
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
To replace, you will need to remove the back cocer by removing the two screws. Take off back cover to access inside. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Sep 26, 2010 | Philips Health & Beauty
Buggy is removing charge from battery
try investing in a battery charger instead of replacing the battery the dune buggy probably doesn't have an altinater to recharge the battery
Apr 18, 2010 | Jeep 36 Volt Battery for Minimoto ATV, Go...
Razor charged but not running
You didn't specify how old you model is.
Generally I would say, the battery is failed.
You might try taking it to whereever you bought it and politely ask for a replacement. Its also a good idea not to leave these in cars during sub freezing weather.
Apr 09, 2010 | Norelco Cool Skin 7775X Electric Shaver
Unknown make of engine
generally the dune buggy was made by a volkswagen chassis and engines
Apr 15, 2009 | 2006 Toyota Camry
Razor USA Razor Dune Buggy Logo
662 people viewed this question
Top Razor USA Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Razor USA Toy Expert? Answer questions, earn points and help others
