Question about Frigidaire FRA186MT2 Window Air Conditioner Cooler - 18500 BTU/h Cooling
What else do you need ?
AC units, no matter if they are big/small, window or big central units. They will only cool the air in the room, or home, to about 15 degrees cooler than the outside air temperature. If you live in Georgia and it is 100?F+ outside, you will be lucky if the unit will reach 80?F even running all day.
Posted on Jul 24, 2012
SOURCE: Frigidaire AC 10,000 btu-not cooling very well
Make sure the filter is clean. Take the unit outside and get some coil cleaner and cleant the coils. You'll have to remove the casing. Also,rinse it from the inside outwards.
Posted on Jul 30, 2010
Feb 04, 2017 | Heating & Cooling
Jun 24, 2016 | Frigidaire Heating & Cooling
May 09, 2016 | Frigidaire Heating & Cooling
Apr 09, 2017 | Polaroid PMP120-4 4GB USB 2.0 MP3 Digital...
May 02, 2014 | Office Equipment & Supplies
Set your Ref/Freezer per the following:
Refrigerators: 36 to 40 degrees. Ideal temp is 37 Fahrenheit. Note: A temp above 42 degrees promotes bacteria.
Freezer: temp should be -5 to 6 degrees Fahrenheit. Ideal temp is 0 degrees.
You have to wait about 4 hours for everything to stabilize. If you are still having ice forming inside the freeezer then the rubber seal around the door is probably the problem. If they have a split, tear or crack, etc. it will let warm moist house air into the freezer and turn to ice as it cools. If this happens in the refrigerator it'll turn to water and collect in the bottom of the frig. New seals can cost around $60 per door.
If you pack too much food in the unit it may also cause freezing because the air needs to move around in there and food shouldn't block the vents in the back walls of the unit.
Hopefully this helps..
Nov 23, 2012 | Spartan Showcase Self Service Cigarette...
Jun 11, 2012 | Danby Silhouette® DWC276BLS Wine Cooler
Aug 24, 2011 | Frigidaire Kitchen Ranges
165 people viewed this question
