If you hear the drain pump running but water stays in the bottom then you have to check if the kitchen sink drain is clear. More particularly if you have a garbage disposal unit in kitchen sink then make sure it is working and has been cleared before running the dishwasher. In case you do not hear any drain pump or it is rough and not draining then it may need to be replaced. The drain pump is available from this site.
F2 is an overfill code. If there is no water in the dishwasher, then you have water in the lower pan that is activating the float switch. You must manually remove the water form the overflow pan by tacking off the toe kick and then the panel behind that to remove the water, or just let it sit for a week and the water will evaporate, assuming there are no internal leaks in the dishwasher. If the code goes away but then returns partway into the wash cycle, you have something leaking and that is the original source of the code.
