JVC KD-G421 CD Player Logo
Question about JVC KD-G421 CD Player
I am trying to plug my phone into jvc kd-g421
5 Related Answers
tstack
SOURCE: jvc cd reciever model number kd-g421
Here you go mate. http://www.online-caraudio.co.uk/ishop/1126/shopscr564.html
£75.00 gets you a new face!
cheers,
thom
Posted on Feb 22, 2008
Anonymous
SOURCE: KD-G421 in Vectra Envoy 99
To stop the memory loss you need to swap the red and yellow wires around. (battery power and ignition power).
To stop the date loss, you need to cut the electrical ariel/remote blue wire.
Posted on Feb 29, 2008
Anonymous
SOURCE: JVC Wire Harness
i need to match up color wire to my 1998 honda accord
Posted on Oct 22, 2008
Anonymous
SOURCE: I have a JVC KD-G421 cd/wma/ipod player and am
i have the exact same problem!!! need help. wont select the input channel, i have radio and cd??? wheres the mp3
thanks
Posted on Oct 11, 2009
josetejas
josetejas
  • 300 Answers
SOURCE: unable to set the clock on jvc kd g421
Press and hold SEL until menu appears
Using the scan button (FWD/REV), select Clock H
Using the volume knob, set the value
Using the scan button (FWD/REV), select Clock M
Press SEL to save and exit
Posted on Jan 22, 2010
JVC KD-G421 - cannot access menu to add ext-in
The JVC KD-G421 only shows the option to change EXT IN from the CD changer to EXT IN when the current source is FM, AM or Disc . See the following page at ManualsLib: https://www.manualslib.com/manual/81662/Jvc-Kd-G421.html?page=15#manual . Assuming the J-Link cable that you added is the KS-U57 or KD-US58, the unit is still looking for (and not finding) the CD changer. Press the SRC button repeatedly until you get to FM or AM. (Disc will only show if there is a CD in the CD slot.) Then try pressing and holding Sel. Use the fast forward/up or fast reverse/down to get to EXT IN on the display. Then turn the tuning knob until EXT IN is selected. Press Sel again to save the setting. Now see if the EXT IN is listed when you press the SRC button. Page 13, https://www.manualslib.com/manual/81662/Jvc-Kd-G421.html?page=13#manual , shows the general procedure for setting the preferred setting mode.
I hope this helps.
1helpful
Unable to set the clock on jvc kd g421 car stereo. Any suggestions?
1helpful
Instruction manual KD-G421
Below is the location of a pdf version of the manual from the Russian JVC website. Even though it is from JVC russia, the manual is in English:
www.jvc.ru/files/instruction_manual/kd-g421_rus.pdf
IPOD CONNECTION
you need the jvc cable compatable for that unit
2answers
JVC Daisy Chain
If your autochanger has an input as well as an output connector it will be possible. The iPod adapter would have to be plugged into the changer's input, and the changer's output cable would run to the KD-G421.
This manual here from JVC shows a diagram on the middle of page 1 where an i-Pod adapter (I'm assuming you have the KS-PD100) is connected daisy-chained with an XM tuner or a DLP unit. Although it doesn't explicitly say that it would work with a CD changer, I don't think it'll be a problem as long as you have an input on the changer.
Jvc cd reciever model number kd-g421
cheers,
thom
7helpful
5answers
CD,s will not play
Read the Manual on Page 2 or get it from:
http://de.jvc-service.net/public/document.cfm?prog=InstrBook.cfm&Model=KD-G321
Just make a reset with a pen or something else.
This should solve the problem.
Best regards
Dirk
Top JVC Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
