Panasonic SC-HT830V System Logo
Question about Panasonic SC-HT830V System
How to add a Switch to Power on and Off HT830 . I just want to use this with my home Stereo System. Is there a Jumper to Install to bypass the CN 501 Socket
Anonymous
    New Friend:
I would wire in an on/off toggle switch just AFTER the fuse that tends to blow out. Its the fuse discussed it another post here on fixay. Currently you can see it at the following address: http://www.fixya.com/support/t120423-display_front_dvd_player_not_working
The fuse mentioned is specifically a fast acting .0 amp fuse from Little Fuse Inc PT# 0491.400MAT1 (FUSE, FAST ACT 125V FA 0.40 Amps). I just ordered this fuse from Digikey.com because my display stopped working. Everything else on the stereo still worked, just the display would not come on. So, installing a toggle switch just after the fuse would seem to me to be an easy way to turn the display on and off, and still have the stereo functional.
Posted on Jun 22, 2013
Horn relay where is it located
Could have DTC"S
B1217 Horn Relay Coil Circuit Failure SJB REFER to Section 413-06 . B1218 Horn Relay Coil Circuit Short to Battery SJB REFER to Section 413-06 .
If the relay had a problem a DTC would be set .
PINPOINT TEST B: THE HORN IS ALWAYS ON Test Step Result / Action to Take B1 CHECK THE HORN SWITCH
  • Remove the driver air bag. Refer to Section 501-20B .
  • Does the horn continue to sound?
Yes
GO to B2 .
No
INSTALL a new driver air bag. REFER to Section 501-20B . TEST the system for normal operation. B2 CHECK THE HORN SWITCH HARNESS FOR A SHORT TO GROUND
  • Key in OFF position.
  • Disconnect: Horn Switch Harness.
  • Key in ON position.
Yes
GO to B3 .
No
REPAIR or INSTALL a new horn switch harness as necessary. INSTALL the driver air bag. REFER to Section 501-20B . TEST the system for normal operation. B3 CHECK THE CLOCKSPRING
  • Disconnect: Clockspring C218a.
Yes
GO to B4 .
No
INSTALL a new clockspring. REFER to Section 501-20B . TEST the system for normal operation. B4 CHECK CIRCUIT 6 (YE/LG) FOR A SHORT TO GROUND
  • Disconnect: Smart Junction Box (SJB) C2280a.
Yes
GO to B5 .
No
REPAIR the circuit. TEST the system for normal operation. B5 CHECK CIRCUIT 1 (DB) FOR A SHORT TO VOLTAGE
  • Install the driver air bag. Refer to Section 501-20B .
  • Disconnect: SJB C2280b.
Yes
No
GO to B6 . B6 CHECK FOR CORRECT SJB OPERATION
  • Disconnect all the SJB connectors.
  • Check for:
    • corrosion
    • pushed-out pins
  • Connect all the SJB connectors and make sure they seat correctly.
  • Operate the system and verify the concern is still present.
  • Is the concern still present?
Yes
INSTALL a new SJB. REFER to Section 419-10 . CLEAR the DTCs. REPEAT the self-test.
No
The system is operating correctly at this time. The concern may have been caused by a loose or corroded connector. CLEAR the DTCs. REPEAT the self-test. TEST the system for normal operation.
1helpful
My iphone is disabled, as i used ubs charger, it is showing 51 , 501 , 501 minutes. and i could not enable as
The only way I know to bypass that is to put it in factory reset mode
which is done with the phone plugged in the computer and holding the home button and power button for a long time.
https://www.theiphonewiki.com/wiki/DFU_Mode
How to factory reset an iPhone any generation
Viper 501 remote start and security system. is there any way to reset the system. truck will start but shuts off when you try to put it in gear.
The quick solution is to power off the security system by removing the power source. Unplug it from the ignition bypass plug and plug the ignition direct bypassing the system.
I just bought used bose 901 series six speakers, hooked them up and they sound great. I was using bose bookshelf speakers before now. If I wanted to reconnect them for a home theater connection, without...
http://worldwide.bose.com/productsupport/en_us/web/901_series6/page.html
If your system is equipped with a tape monitor loop, you can switch the EQ out of the circuit by disengaging the tape monitor switch. If the EQ is connected to the pre-out / main-in jumper, you would have to defeat the EQ before you hook up a conventional speaker. I don't believe the EQ has a defeat switch - you'd have to rig a bypass.
Once defeated, if you have a system equipped with a Speaker A / Speaker B selector, the smaller speakers could hook up to the second system. If that's not possible, speaker switches are available for reasonable money. It is very important, though, that the 901 EQ i defeated when using conventional loudspeakers.
Emachine ET1810 is not powering on already replaced the power supply
You may have a bad Power On switch. The Power On switch is located inside the plastic Power On button.
This is a generic ATX power on switch, that I have found works in many computers,
http://www.directron.com/atxswitch.html
Have you bypassed the Power On switch?
If you bypass the Power On switch, and the Power Supply comes on, you have a bad Power On switch.
If you bypass the Power On switch, and the Power Supply does Not come on, you have a bad Power Supply.
Sometimes a new Power Supply can be bad.
Make SURE the ATX main power cable is plugged in tightly.
(I have had an instance recently where I bypassed the Power On switch, and the Power Supply came on, but only as long as the jumper wire was in place. Remove jumper wire? Power Supply went off. Removed the jumper wire, then pressed the Power On button. The Power Supply came on )
Bypassing the Power On switch has nothing to do with the switch itself, or the wires to the switch.
A jumper wire is used in the connector for the ATX main power cable.
My sources indicate the ET1810 uses a 24-pin ATX main power cable.
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
A jumper wire is used to connect the Green wire (Soft Power On. Also abbreviated as PS_ON) to ANY Black wire. (ALL Black wires are Ground wires)
Looking at the photo to the far right, you will see the Green wire goes down into a socket hole.
This is the Back of the connector.
The jumper wire goes down into the socket hole RIGHT NEXT to the Green wire.
The jumper wire has to go down into the socket hole pretty far.
(Approximately 1/2 inch)
At the end of the Green wire is a metal terminal. The jumper wire has to go down into the socket hole, far enough to touch that metal terminal.
Same thing for ANY socket hole with a Black wire.
(The Green wire is the Soft Power On wire. It is a 5 Volt DC wire. The Black wires are Ground wires.
The jumper makes a circuit from the Soft Power On wire to a Ground wire)
The jumper wire usually preferred is a paper clip straightened out, then bent into a U-shape.
The middle of the U is wrapped with black plastic electrical tape.
This is where your fingers hold the jumper wire.
One end of the jumper wire goes down into the socket hole with the Green wire.
The other end of the jumper wire goes down into a socket hole with ANY Black wire.
The contact is no more than 2 seconds.
My sources indicate the motherboard is an ECS MCP73VT-PM
(EliteGroup)
1helpful
My desktop computer wont power on
Suggest you see if the problem is the Power On switch, or the Power Supply.
(First check to see if the receptacle in the surge protector, that the computer is plugged into, has power.
Have had a few bad surge protectors, where just THAT receptacle was bad.
"Hmmm, surge protector power on LED light is lit. Monitor, printer, and router have power, that are plugged into the surge protector.
Plugged a lamp into THAT receptacle, and found it to be bad)
To test whether the Power On switch, or the Power Supply is bad, a jumper wire is used to bypass the Power On switch.
[ The Power On switch is located inside the plastic Power On button.
This is an example of a generic ATX Power On switch, that I have found fits many computers,
http://www.directron.com/atxswitch.html ]
The jumper wire is used on the 20, or 24-pin ATX main power cable's connector.
While still plugged into the motherboard.
The jumper wire connects to the Soft Power On wire, (Green), and to any Ground wire. (Black)
Example of a 20-pin ATX main power cable, and it's respective connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Example of a 24-pin ATX main power cable, and it's respective connector,
Using the jumper (Wire) to bypass the Power On switch, turns the Power Supply on?
The problem is a bad Power On switch.
Using the jumper to bypass the Power On switch, does Not turn the Power Supply on?
The problem is a bad Power Supply.
There is a correct procedure for performing this test.
Post back in a Comment if you wish to know.
Regards,
joecoolvette
Stereo went dead while increasing volume to full blast which resulted to heating system not working as well. Tried bypassing behind the stereo and worked.Would like to the know cause and remedy pls.
How much power/wattage is your amp? What kind of car?
You may need to install a capacitor to harness some power to run the system, its ******* your cars electrical system.
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
