Sony KV-32S45 32" TV Logo
Question about Sony KV-32S45 32" TV
No picture, but sound
Had a thunderstorm the other day. Power went out but came right back. TV has cable box hooked to it. When I turned on the tv, only snow. Could adjust sound level though. I hooked up another tv to converter box and converter box and tv worked. Maybe Sony tv tuner got fried during power surge from storm?? Cannot change channel either with remote or on set.
Posted by stal on
francoise cleofas
    Genius:
  • Sony Master
  • 2,432 Answers
Tried to hooked up with an air antenna. if you can not get any channel and just a white raster or snow, it could be the tuner get fried.
Posted on Jul 23, 2012
5 Related Answers
Anonymous
SOURCE: No picture, stuck on Video 1, volume self-adjust to maximum
the tacticle (micro switches)on the front of the main chassis have most likely gotten wet at some time,I suggest replacing them all.
Posted on Apr 06, 2007
Anonymous
  • 4234 Answers
SOURCE: TV won't turn on
The set is in protective shutdown because a problem was detected. The 5 blink code indicates that the problem circuit. In this case it is the blanking circuit. Were there any indications of problems prior to the storm? If not, I'll need to lok up this one for the specifics. Do you intend to repair this yourself?
Let me know and I'll provide the details.
Thanks,
Dan
Posted on Jul 07, 2008
Anonymous
SOURCE: My Sony Trinitron TV does not respond to remote control commands
the tv wont come on the standy timer light is on
Posted on Jan 02, 2009
Anonymous
SOURCE: Sony KV-30HS420 turns off all by itself
This is less a solution than a work-around, but it does work for me, and it is free or low-cost.
I have had the same problem on the same Sony (model KV-30HS420),picture fading out to green then black, then turning off by itself,after which sometimes the light blinks 6 times, other times it blinks 7times. This started about four years after I bought it, which is not adecent lifetime for a CRT TV. It would happen anytime from 2 or 3 timesan hour to 30 to 40 times an hour. After getting absolutely nowherewith Sony, which was completely unresponsive and unhelpful, and which refusedto stand by their product or provide any useful information, I wasgetting ready to buy a new LCD TV, any brand but Sony (never buyanything from them again), when on a whim I decided to try one last stopgap solution.
I put a fan up against the side of the TV, blowing into the vents. Ithas been 3 days now, and not once has the fading and shutting downoccurred. So it looks like the fading out and shutting down wassomehow related to heat, and the ventilation seems to have solved it. I don't know why it should be a problem now, when it was not the first fewyears. It is also a mystery why Sony has not been able to figure thisout, since it is clear from online postings that many people have thisproblem with this model. Give this a try and see if it solves theproblem for you.
Posted on Feb 10, 2009
Anonymous
  • 10594 Answers
SOURCE: how to turn off channel number displayed in TV screen
Press " i " (info) button on Sony TV Remote so on-screen display will disappear.
Posted on Jun 09, 2009
How do I get picture back on TV which was working the night before, which is hooked up to HD cable box, thru HDMI?
OS info is always helpful, if say you are running some type of nix, it's likely not getting recognized by xserver or if your running some version of windows your display manager has shut it down because of a resolution mismatch.
My tv won't work after I shut it off using the remote throught the cable box
You need to turn on the cable box again. Make sure to select the right source again for your tv.
While dusting, the tV went off and we can't get it back on. It is a Samsung, about 2011 or 12, about 46inch, hooked up to a sattelite.
It seems you accidentally touched either a signal cable connected to the TV from the Satellite receiver or the power cable from the electrical outlet. Try removing and reconnecting both cables. If the power cable is not connected right then the TV will not turn on at all; and if the signal cable is loose then the TV should turn on but there will be no picture. Another possibility is that the fuse at the fuse box tripped due to an accidental short circuit. Go to the main fuse panel and reset/replace the fuse depending on what kind you have. Most fuses these days can be simply reset. Hope this works. Electronic parts inside the TV rarely go bad so soon. Solid state electronics are pretty sturdy.
Turned power on went to input, selected tv mode, sound comes on but no picture. tv is hooked to coax cable and box from company.
Make sure the resolution from the box is not on 1080p. The highest should be for that set is 1080i or 720p.
My wife thought it was hooked to a cable box for high number channels and pushed 707 on the remote TV sig went out. TV powers up but no menu no signal just a power light and the background is on but no...
Hello
have you tried pushing 003 on the remote or the AV buttons?
All I can think of is that you must the get tv BACK ON the right channel or AV Input.
Hope you have a better day
LCD TV is hooked thru cable box. When you use the
Try this (may not work):
1. UNPLUG power from TV at wall outlet.
2. Turn ON the TV (with no power cable plugged in).
3. Plug power cable back in (at wall outlet)
4. Turn ON TV (don't use remote this time).
Hope this works!
1helpful
No picture 2 days ago power went out thru out the neighborhood, once power came back TV worked great. today, go to power on TV, here it clicking, but no picture... cable box working, cable working in 2nd...
It sounds like there`s a sort on the secondaries of the power supply. Before the power went off, did you ever turn the tv off by unplugging it?? In other words, did you turn the power off completely to the set or leaving it in standby?? if you always left it in stby, it will be the capacitors in the power supply, they dry out if the power is always on, so they will need replacing. If you did turn off the power, then I think you`ll find that the power cut had nothing to do with the fault you`ve got now, it will be the Line Output Stage which has failed or gone short circuit. Ian
Female coax connector in tv bad?
If your cable converter box has audio/video connections on the back of it,you don't need to worry about using that RF coax connector. Just hook it up the same way your DVD is hooked to the TV input jack. Get a 3-wire cable (yellow-red-white)hook it to the same colors on the back of the cable box and hook the other end to an unused input on the back of the TV. Then select that input with your remote and watch TV.
Volume on tv set not right
Try unplugging the TV for 2 minutes then try again.
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
