I have a Sony DSLR-A100 with display issues. The camera will take a picture and store it on the memory card, but the display does not allow any navigation of files or menu options. It just gives a quick display after photo is captured and that is the only time the screen has anything displayed. It also seems to be coupled with an intermittent lens/ focus issue as I occasionally here a series of unusual "flickering" followed by loss of auto focus functionality.
SOURCE: Format error in Sony Cyber-Shot DSC-S650
Format the memory stick via setup menu inside the camera. Let me know if this works.
SOURCE: MY MEMORY CARDS NO LONGER
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.
Best regards - Michael
SOURCE: Sony Alpha 100 gives error message when attempting to take pic.
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. I was getting the same error message as reported above: "Unable to use card" then "Format?" then that format fails. Thinking the camera
failure.]
SOURCE: The lens kit of my Sony DSLR A200 produces noise
If it's in continuous auto-focus and doing it, then it is just not locking on to one thing and jumping back and forth between two objects that are very close together in distance and it is normal. It should stop in manual, single shot or single point auto-focus. Sony uses Nikon auto-focus technology and my D-300 with a 70-200mmf2.8 will do it if I turn the auto-focus tracking time(lock-on) all the way down with the auto-focus in full auto.
Testimonial: "Thanks for the info"
SOURCE: I have a sony dslr-a100 and I upgraded to a four
Is the new card "cheap"? If so, it may be too slow to keep up with your camera.
