Question about Ranger RCI-6900F-25 CB Radio
How do i adjust the sideband
Side band is off frequency
Posted by john on
odugbemi hameed
    Guru:
  • 166 Answers
Instructions
Connect one end of your coaxial cable to the output port on your SSB Transmitter. Connect the other end of the cable to the coaxial input port on your RF demodulator.
Connect one end of your 1/4 inch audio cable to the audio output port on your RF modulator. Connect the other end of the audio cable to the audio input jack on your amplifier.
Turn on your SSB transmitter, RF modulator and amplifier. Adjust your SSB transmitter modulation by adjusting the knob on your RF
Posted on Jul 22, 2012
1 Related Answer
Anonymous
  • 39 Answers
SOURCE: sideband freq
That is wrong , I used to have a freq. counter that only read when you applied RF to it on my old Tempo rig and I ran lower 37 and upper 35 so I would key the radio on am and tune the vfo to that frequency and would be on frequency with everone else,I remember hearing that once long ago but it's not true.
Posted on Feb 21, 2009
Uniden washington cb
Is it off on both upper and lower sideband? how about AM? Did someone mod it so that the clarifier works on transmit too? Hope not.
If it is off on LSB adjust CT2 next to C104 and for upper side band CT1 next to C105. You will be tweeking on a capacitor in series with a crystal. caution as it could stop it from transmitting (oscillating) if it isn't set right. best if you use a frequency counter to see if the stage is working right on frequency. Here is a diagram hope you know how to read one. If you dont and you attempt to tweek on this and that, you have a great chance that you could foul it up to the point it wont work at all or sound really bad. The main thing is to narrow it down where the problem is: Is it just LSB or USB or both? If both do not tweek on C1 or C2. I would say it is the 11Mhz crystal area. meaning the problem could be a bad varactor diode, even a resistor or capacitor failure in that portion couldmake it off frequency as the varactor is voltage controlled. By varying the voltage to it, the capacitance changes and therefore changing frequency.
If both uper and lower sideband are off then I suppose AM is off too. the reason you are not being heard as well. Adjust CT3 to bring it back on frequency. You got it CT3 if upper and lower and AM is off or if only lower is off CT1, if only upper is off CT2.
Good luck. I am not responsible for your actions. I am only giving my opinion and logic on this. here is the diagram, dont hurt yourself.....
http://www.cbtricks.com/radios/uniden/washington_mb8719/graphics/uniden_washington_mb8719_sch.pdf
Dec 23, 2013 | Radio Communications
Fix my connex 3400 hb sideband button
Hi there, if you are talking about the Connex CX 3400 HP there is no sideband or SSB on this radio. It is only AM and FM 10 meter Ham radio. Many people do modify these radios to include the 11 meter frequencies which is the CB band. Maybe knowing the actual bands and their frequencies will help some too this radio does have 6 different bands ranging from (Band A. 28.015 thru 28.455) (Band B. 28.145 thru 28.585) (Band C. 28.115 thru 28.555) (Band D. 28.085 thru 28.525) (Band E. 28.055 thru 28.495) (Band F. 28.025 thru 28.465.) I hope this will help you. Bob
May 13, 2012 | Connex CX-3400hp AM/FM 10 Meter Amateur...
Looking to find the frequenecies of the upper and lower channels
  • Hi I can help.
  • For the Grant 40 channel CB there are 40 frequencies I will list below.
  • When you refer to the upper and lower channels for this raidio you must mean USB (Upper Side Band) and LSB (lower side band).
  • This is called single side band modulation which is to say the the carrier is removed from the upper or lower sideband depending on which your pick and the signal goes farther on less power.
  • So the upper and lower side bands are the same frequency just upper side band or lower sideband.
  1. 26.965 MHz 21. 27.215 MHz
  2. 26.975 MHz 22. 27.225 MHz
  3. 26.985 MHz 23. 27.255 MHz
  4. 27.005 MHz 24. 27.235 MHz
  5. 27.015 MHz 25. 27.245 MHz
  6. 27.025 MHz 26. 27.265 MHz
  7. 27.035 MHz 27. 27.275 MHz
  8. 27.055 MHz 28. 27.285 MHz
  9. 27.065 MHz 29. 27.295 MHz
  10. 27.075 MHz 30. 27.305 MHz
  11. 27.085 MHz 31. 27.315 MHz
  12. 27.105 MHz 32. 27.325 MHz
  13. 27.115 MHz 33. 27.335 MHz
  14. 27.125 MHz 34. 27.345 MHz
  15. 27.135 MHz 35. 27.355 MHz
  16. 27.155 MHz 36. 27.365 MHz
  17. 27.165 MHz 37. 27.375 MHz
  18. 27.175 MHz 38. 27.385 MHz
  19. 27.185 MHz 39. 27.395 MHz
  20. 27.205 MHz 40. 27.405 MHz.
  • If you have any comment please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 29, 2011 | Uniden GRANTLT 40-Channels Base CB Radio
Not transmitting good at all on ssb the power come back
Did you have your radio "peaked?" If you turn a Cobra Sideband radio up to much it may be great for the AM side but can crush the Sideband side. Make sure it is on frequency too. Use a frequency counter to check. Make sure your SWR is 1-1:5 and no higher than two. You may have to take it to a tech and have them but it on a scope.
Mar 07, 2011 | Cobra 148 GTL 120-Channels Base CB Radio
Galaxy 99 has same frequency 27.185 on am also on upper side and lower side band how come?? thank you
The frequency doesn't change when you change to USB or LSB. Basically the AM frequency takes up a certain amount of space, known as bandwidth, so it could fill in for example use 50 hertz above and below 27.185 giving 100 hertz bandwidth. When you use sidebands the am bandwidth is split in two so the upper side band would use the 50 hertz above 27.185 and the lower side band would use the 50 hertz below. The idea is that twice as many operators can operate without interference.
Sep 17, 2010 | Galaxy Radios DX-99V 40-Channels Base CB...
I have a FT-8900 and want to be able to open the AM side so I can use it on frequency 26.805 is there anyway it can be done
The Yaesu FT-8900 is a quad band FM transceiver only. It can not be modified to receive or transmit AM, SSB, RTTY or CW. It works on all or portions of 70 centimeter, 2 meter, 6 meter and 10 meter bands. The 26.805 Mhz frequency is 11 meters, so it is out of range of the 10 meter band in the radio, it is close. Even if able expand the transceiver, the AM / SSB mode commonly found in this band makes it impossible to use. Further, the radio is not FCC Type Accepted for use in this band.
Sep 05, 2009 | Yaesu Radio Communications
Sideband freq
Feb 21, 2009 | Galaxy Radios DX-2547 40-Channels Base CB...
Sideband carrier??
im not sure carriers are measured in pounds, but SSB is a supressed carrier mode, in SSB only one sideband is transmitted and the carrier is inserted at the other end in the receiver. In AM mode the carried and both sidebands are transmitted. with regular am there is a carried and when modulation (your voice) is added a signal appears both above and below the carrier frequency at a distance relative to the frequency of your voice. so if you have a carrier at 1000 khz and modulated it with a tone of 100 hertz the signal will contain frequencies of 900,1000, and 1100 hertz, then its changed to SSB by supressing the carrier (1000) and one sideband (1100) if you are on lower sideband and (900) if you one upper sideband, and transmits the remaining frequency.
Nov 06, 2008 | Ranger RCI-2995DX Base Scanner
Connex 3300 hp
U mean on sideband? Frequency counter only useful on other than sideband operation. This does not mean the carrier insertion osc. is on frequency. If it needs adjustment, your voice will sound high/ low on transmit. Incoming signals will sound right after adjusting the osc.
May 14, 2008 | Connex 3300 240-Channels Base CB Radio
Switching radio bands
what radio do you have? does it even have sideband channels? some radios don't come with them, of fm or upper or lower side bands and short wave
Dec 08, 2007 | Connex 3300 240-Channels Base CB Radio
Radio Communications Logo
149 people viewed this question
Top Ranger Radio Communications Experts
Robert McClure
normis101
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
