Question about KitchenAid 20.3 cu.ft. Counter-Depth Bottom Freezer Refrigerator
Kitchen aid kbl refrigerator
Computer control board is bad
Anonymous
SOURCE:
Anonymous
SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Posted on Feb 18, 2008
Anonymous
SOURCE: kitchen aid superba side by side refrigerator
I slid our unit out tonight and took off the cardboard cover and vacuumed the back area out.  If you do this unplug the unit. I didn't see the spinning fan blades next to the compressor until after the vacuum nozzle touched them.
I then took off the front cover down by the water filter.  We have 2 long hair cats. 5 years of fur had collected and was preventing air from circulating out the front of the unit. I vacuumed out the fur.  I then took a short flexible rubber tube and hooked it to the vacuum and got as much fur and dust off the coils underneath the fridge box.
Once I had everything put back together and plugged back in the frame cooled down and I think we are OK.  My guess is the hot air could not escape so it was gradually heating up the frame.
Good luck.
Posted on Aug 20, 2008
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: Kitchen Aid Refer: KSSC42FMS01: The freezer, doesn't go below 32
How long have you had this refrigerator and is this the first time this has happened? Your refrigerator has a control board and I believe the board is causing the refrigerator not to defrost every 8 hours. Let me know these questions and I will help you resolve this. Thanks, Sea Breeze
Posted on Mar 19, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: kitchen aid refrigerator freezing in refrigerator
Could you look inside the door near bottom outside frame of fresh food side and get the model numbers for me to assist you better. Also if you have a way to check the temperature as you change settings on the thermostat for the fresh food section. We need to see how the thermostat responds to changes in settings. If no changes then we need to focus on the thermostat. Also there is duct that comes from freezer that can have a damper opened or close to different settings. Let me know the model and I will pull up the drawings for your model. Thanks Sea Breeze
Posted on Mar 20, 2009
jan mczeal
Jan McZeal
  • 632 Answers
SOURCE: water from the kitchen tap is good tasting, water
The water has been in the tank for too long. Draw and discard a least 7 glasses of water to freshen the supply. Draw another 7 glasses of water or more to completely rinse out tank. Repeat the process if necessary.
Posted on Oct 26, 2009
Refrigerator kitchen aid model KSCS231NSS00
You need a new main control board- the capacitors go bad on these whirlpool built controls quite often, they have replaced it with a three part kit, but I would send the board you have to a refurbisher like Corecentric Solutions or Fix-your-board... They offer a warranty with the repair also. Main Control Board WPW10219463
Jul 05, 2016 | KitchenAid Refrigerators
Refrigeratory cycles on and off & beeps
You will need a main control board W10219462 either rebuilt or replaced. Now there are companies who rebuilt these but not approved by Kitchen Aid to do so. As a certified repairman I would advise you to call Kitchen Aid to see if your unit have a board replacement yet. As of December 2015 your model hasn't made the list yet. I would call them and check, what will happen is your unit will start being erratic with temps and had to control for food. I wish I had better news for you, good luck.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Feb 13, 2016 | KitchenAid KBFC42FSS Stainless Steel
Kitchen aid ksss42 not cooling fan runs
With this particle number you gave there are over 40 different models. So I seek a better model number or a complete number to assist you better. Some models had a inverter to control the compressor and I have seen failure due to heat or surges. But without a model number to verify I can't and won't direct you on a fish hunt without the correct information. Get back to me with more information please.
Aug 25, 2014 | KitchenAid Kitchen Aid 42" Built In...
Kitchen aide refrigerator no power at compressor dont run
Have you replaced the=> 2154958 Defrost Control Board? Those symptoms are very common for a defective 2154958 Defrost Control Board
Let me know, Thanks JT
Jan 24, 2014 | Whirlpool GS6NBEXR Side by Side...
Might be a defrost problem. or maybe a damper or bad fan motor. Look in the freezer for signs of frost on the back wall. If you see it then that means the frig is not defrosting. Unplug the unit for a few days and if it goes back to normal operation that will confirm a defrost problem.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 22, 2013 | Refrigerators
Mar 19, 2009 | KitchenAid Refrigerators
Kitchen aid superba electric convection range
ouch thats gotta hurt!! how about the clock os that back on atleast??? sounds like a bad thermo stat on the back wall of the unit maybe a quater sized thermo 1 wire in one out, should have ( BUT DOUBt it does) have continuity through it. ifthe clock still doenst work ther is also a small inline thermal fuse connected right to the wire warness connecting to the main control
Mar 18, 2008 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid 20.3 cu.ft. Counter-Depth Bottom Freezer Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
geob91
Dakshinamurthy...
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
