Question about Olympus SP-350 Digital Camera
Olympus SP-310 Firmware download 1.3 - Olympus SP-350 Digital Camera
5 Related Answers
Anonymous
SOURCE: Olympus SP-350 USB Device Not Reconized
Hi
You have to take out the card before you switch on the camera. Switch on the camera and then put in the card. Then it works
Posted on Jul 18, 2008
Anonymous
SOURCE: Zoom Error
Have you tried changing the batteries to new/charged ones?
Posted on Oct 17, 2008
Anonymous
  • 919 Answers
SOURCE: download driver
To learn about the new and free version of Olympus Master 2 software go to:
For Windows:
http://downloads.olympus-europa.com/OM2/win/OM211Setup.exe
For MAC:
Olympus Master 2.11: http://downloads.olympus-europa.com/OM2/Mac/OM211EN.dmg
This software replaces all previous versions of Camedia Master 4.x and Olympus Master 1.x.
Posted on May 20, 2009
HarryHarley
Harry
  • 343 Answers
SOURCE: my olympus sp-310 camera shows empty battery but I
Are you sure you put them in with the correct polarity facing the right way. Its a common mistake.
Also try a "known" set of batteries just to make sure.
Good luck
Posted on Jan 21, 2010
Anonymous
SOURCE: Olympus - SP-310 camera. Has broken LCD screen.
I Have a sp310 camera... It has a problem with optical zoom. Do you like to sell me your camera ou can you buy my camera?
Posted on Feb 20, 2010
3answers
Olympus SP-310 Problem
You might try adjusting the battery terminals
if it has springs pull them up a little clean the
contacts. tape & cushion the batteries down so they
dont move around. this has worked before for me in
situations as you describe it worth a try.
Nov 19, 2007 • Cameras
How do you delete images on the Olympus sp 310
The delete button is above the LCD monitor on the back of the camera, the second button from the right, marked with a trashcan. While viewing the picture you want to delete, press this button. The camera will prompt to make sure you want to delete the picture.
My olympus sp-310 camera shows empty battery but I have a new charged batterys in it
Good luck
2helpful
2answers
I am not getting the suff.no of snaps as batt is getting down for olympus( sp-350) . i have tried several type of AA 2500 mAh Ni-MH battery and purchased new LCD (simpex) charger.then also same.also when...
The problem you describe is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the inside contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe the ends of the batteries and replace them in the camera. This clears up the problem about 90% of the time -- I hope it works for you.
My Olympus SP-310 has wavy lines in all the pictures. I found a solution before on the internet - it recommended changing one of the settings. However, I can't remember what it was, and I can't find t
If the camera was working fine "before" you made a setting change, try going into the setting and selecting "factory Default" That may correct the setting you may have experimented with. And, make sure your battery is fully charged first!
Need serial number
For Windows:
For MAC:
This is a free download so there is no serial number required to load the software to the computer.
Zoom Error
Olympus SP-350 Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Are you an Olympus Camera Expert? Answer questions, earn points and help others
