Question about Mitsubishi VS-45609 TV
Mitsubishi 45609 error code 1-2
Error code is 1-2 after holding down the input and menu button picture comes on after I plug it in then turn it on and press the power button it times out after about 10 to 20 seconds like the timer is in use. So whats the error code mean and what should I do to fix this?
  • shane dake
    shane dake Jul 22, 2012
    Can anyone get me a picture of where to locate these convergences??
6ya staff
SOURCE:
Anonymous
  • 957 Answers
SOURCE: Mitsubishi 72" projection TV I turn on and then turns off
If this this a LCD projection It may be a faulty lamp. It is a great idea to call the support center. they can walk you through it and advise you too.
Posted on Apr 26, 2009
rustym62
Rusty Morales
  • 201 Answers
SOURCE: My Mitsubishi 65 inch DLP will not turn on.
looked up owners manual that was a waste of time, hmm the number one issue on this type of set is issues with the lamp. How old is it? Has it ever been replaced? Sometimes a visual inspection of lamp can fool you, but typically as they age a milky haze develops on the lamps glass or if it popped the lamp will be shatttered inside. Can't hurt to check it. make sure set is unplugged first just to be safe.
Posted on Apr 30, 2009
Anonymous
  • 87 Answers
SOURCE: My 2 1/2 yr old Mitsubishi 65 inch DLP will not turn on.E code 12
let it start up you will here things happening, engine will start first then a buzz to start the lamp if you here all of this you have a bad lamp.You should have a error code let the tv try to start leave it alone and see if you have an error. As soon as you reset the tv you loose the error.
Posted on May 01, 2009
Anonymous
SOURCE: Mitsubishi WT-A42
I repaired a convergence problem on this model by locating IC8C01 and IC8C02, the two large convergence chips on the main pcb(center board) and solder all the leads making sure not to leave any solder bridges! The unit was over 4 years old and used often. Those chips get pretty heated and make the solder brittle and crack around the leads.
Posted on Jun 09, 2009
jhinsincity
Julio Hernandez
  • 616 Answers
SOURCE: Power light comes on for 2 seconds and then off.
Need to have the power supply rebuilt, expect to pay around $350 Julio at [email protected]
Posted on Jul 21, 2009
Sanyotv com
Sanyo TV Service Menu Method 1
1.Unplug the power cable.
2.Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
3.Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
4.Use the {CH+} {CH-} buttons to select menus.
5.Use the {VOL+} {VOL -} buttons to change settings.
6.Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
7.Press the {MENU} button or turn the TV off to exit.
Sanyo TV Service Menu Method 2
2.Press and hold the {VOL -} button on the TV while plugging the power cable back into the outlet.
3.Keep pressing the {VOL -} button until the TV powers on with the Service Menu displayed.
Sanyo Projector Service Menu Method 1
Factory Menu Access
1.Press and hold the {SELECT} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Factory Menu will be displayed.
Service Menu Access
1.Press and hold the {MENU} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Service Menu will be displayed.
Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
To exit, turn the Projector Off.
Sanyo Projector Service Menu Method 2
1.Press & hold the {MENU} button on the Projector for about 10 seconds.
3.Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
4.To exit, turn the Projector Off.
Jul 20, 2013 | Televison & Video
Hitachi 46w 500 screen says locked
reset the tv by pressing the reset button.
Aug 21, 2008 | Televison & Video
Tip
Service menu codes hitachi misc.
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
PROJECTORS :
* Press the {MENU} & {RESET} buttons and then press
the {RESET} button again and hold it for at least 5 seconds.
* The Service Menu will be displayed.
* To exit, turn the Projector Off.
MISC :
1.
* Turn the TV on.
* Press the {MENU} {MENU} {8} {SELECT} buttons on the remote.
* Use the {UP} {DOWN} buttons to select items.
* Use the {LEFT} {RIGHT} to change the data.
* Press the {EXIT} button to exit the Service Menu.
2.
* Turn the TV off.
* Press and hold the {INPUT} button on the TV then press {POWER}.
* Hold both buttons until the TV powers on
3.
* Turn the TV off.
* Press {POWER} & {INPUT} buttons on the TV for more than 3 sec.
* The letter "P" indicates picture and "A" indicates audio.
* Press the {EXIT} key to exit the Service Menu.
on Apr 29, 2015 | Hitachi Office Equipment & Supplies
When I push the on button the green light comes on for second or two then goes out.(will not stay turned on long enough to even get a picture on the screen.Mitsibishi Model # WS-55315
This set has a self check feature--if set has been unplugged it clears the error buffer--plug in and try to turn on set.
When green light comes on and then goes off ON THE FRONT OF THE SET press and hold BOTH the menu and input(device) buttons at same time for at least 5 seconds and release both buttons.
Power light will blink a 2 digit error code like 2 blinks, 2 blinks, a pause and repeat the code for a total of five times.
Let me know what error code you find and I will explain it.
May 27, 2012 | Mitsubishi Televison & Video
Mitsubishi ws55813 picture turning off
The model indicated has a self check feature.
If turned on and green power light comes on and a few seconds later goes out:
On front of set press and hold both the menu and input(device) buttons at the same time for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it for a total of 5 times.
Let me know what error code you find.
If you unplugged the set--you will have to plug it back and attempt to turn it on--unplugging set clears the error buffer.
May 16, 2012 | Televison & Video
My Mitsubishi TV power light comes for about 12 seconds, without any picture, and turns off.
Try the self check when power light goes off, on front press and hold both the menu and input buttons for at least 5 seconds and let both go.
Power light will blink a two digit error code like 2 blinks,2blinks, pause and repeat it several times.
What error code do you find?
SD TECH
Oct 18, 2011 | Mitsubishi VS-55609 55" Rear Projection...
Green light comes on then imediately turns off picture has no time to come on
This model has a self check: When set and green light go off on the front of the set press and hold both the menu and input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will blink a two digit error code like 2, 2, and repeat it several times.
Let me know the error code and I will tell you what it means.
regards, SD TECH
Sep 17, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubisi wt-46809 will not turn on. i plug it in and it blinks 3 times then nothing. no error code when i hold menu and input
keep in mind if you unplug set it clears the error buffer.
Try to turn set on and if power light comes on and goes off then do the self check; menu and input for at least 5 seconds and release both buttons.
UNPLUG TV ANDTHEN PLUG BACK IN---TURNON---GREEN POWER LIGHT COMES ON FOR A MOMENT ANDGOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Before you rate this information let me know what you find.
SD TECH
Jul 20, 2011 | Mitsubishi WT-46809 46" Rear Projection...
Hello, When the power button is pressed it gets power than immediatly turns off. The screen never comes on on with a picture either. Any ideas? THANKS :)
If model number listed is correct----do the self check:
When power light goes out, on the front of the set press and hold both the Menu and input buttons at the same time for at least 5 seconds and release both.
Power light should blink a error code: most common is 2 blinks, 2 blinks, a pause and then it repeats at lease 5 times.
Let me know which error code and I will tell you what it means.
SD TECH
Aug 14, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi VS-45609 TV Logo
85 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
