Cutting head started smoking after 30 minutes of use. It was so hot that the plastic on the head melted. Purchased a new replacement assembly head, and the same thing happened, except it took only five minutes to start smoking/melting.
I think the melting is in your the head the feed that hods the line. That's the plastic bit. I have had this happen not just with one brand either. The problem is vibration. if things are not properly balanced the head vibrates, the resulting friction causes heat, that causes more wear and more heat. End of strimmer head! I not buy them two at a time on ebay!
SOURCE: Husqvarna Gas Line Trimmer Head melting
wrong fuel/oil mixture...try 25mls of oil per litre fuel.
Not necessarily solving your problem but I've owned 2 335RX brushcutters with shaft bearing problems. Depends on how far up the shaft gets hot. Bearing failure in the centre/upper bearings wouldn't be likely to melt the head. Dealers tell me the product isn't up to the job and don't recommend Husky trimmers/brushcutters to their customers. Husqvarna UK are not interested. Won't buy another Husky. The head may also be short of grease, causing the overheating. Take off the grease bolt and inject some in to see if it helps. If it has been hot enough to melt the plastic head there has probably been damage to bearings and seals. Hope you solve your problem.
