LED is red while connected. Been charging for a couple days. HELP!
SOURCE: Mad Catz Lynx Wireless Controller PS2 with blinking red light.
I have one of these and what i usually have to do is plug the little part in which plugs in to the ps2 then let that load for a few seconds then try turning on the controller.
Hope it helped =]
SOURCE: mad catz gamepad for ps3 wont work..help
On Most Models They Will Work When You Hit The Reset Button On The Bottom Of The Receiver.
SOURCE: need pass key for mad catz bluetooth item no. 8860
Try entering six zero's if that does not work try four zero's
SOURCE: My mad catz racer wheel for PS3 will not connect
finally figure dit out. u haveta hold down the center madcatz button as u hold down the home button at the same time. stoopid instructions did not word it that way as usual.
SOURCE: Mad catz controller blinks but won't connect
Go to Settings then System Settings then System Information. Once there check the "Version" of the System Software. If it's over 3.5 your "third party" controller is no longer supported. i.e. it will no longer work. Sorry, same issue here. :-(
Pairing is a process of associating
Bluetooth devices with each other. It will establish a permanent
security link between the devices and enable quick access to the
services provided without the need to re-enter Pass Keys. You will only
need to pair your PS3 and the Headset once.
Paired devices remain paired
even when:
-One of the devices is powered off.
-A service connection is interrupted or stopped.
-One or both devices are restarted.
Pairing the Headset with the PS3
Before the Headset can be used with the PS3, the two devices must be
'paired' so they can communicate with each other. Use a gaming
controller for this procedure and ensure that the Headset is powered on
(flashing blue LED light) and that it is not being charged via USB
cable.
1. Power on your PS3 console.
2. Within the "Settings" menu, press X
on "Accessory Settings."
3. Press X on the icon labeled: "Manage
Bluetooth® Devices."
4. Scroll down and press X on the icon
labeled: "Register New Device."
IMPORTANT: Depending on
your model of the 8860 Bluetooth® Headset, your power button is either
an oval shape with an icon of a circle with a line going through it (5a)
or it is a button with a phone icon (5b). Please follow the appropriate
next step depending on your model of the 8860.
5a. Once at the next screen, prepare the
Headset to be paired with the PS3 by holding down the K1 button until
the LED flashes Blue and Red (hold K1 approx 12 seconds).
5b. Once at the next screen, prepare the
Headset to be paired with the PS3 by tapping the pairing button located
next to the volume controls on the side until the LED flashes BOTH Blue
and Red.
6. Once the Headset's LED indicator is
alternately flashing Blue and Red (indicating the Headset is ready to be
paired), press X on "Start Scanning."
7. Once Scan is complete, the PS3 will
recognize all Bluetooth devices within range.
8. Locate "8860" from the list of
available devices and press X on its icon to be prompted for a Pass Key
9. Enter 0000 (four zeros) as the Pass
Key and press X on OK
10. You should then be taken to a new
screen stating: "Register completed"
Troubleshooting
Q.
The PS3 is unable find the Headset.
A. If the Headset has been paired with another Bluetooth device, the PS3
will have trouble finding the Headset. Either remove the Headset from
the paired device or turn off the Bluetooth power on the paired device.
Q.
The Headset cannot be activated after being charged for 20 minutes.
A. To activate the Headset, the battery needs to charge for at least 40
minutes. It is highly recommended to fully charge the battery before
use.
Q.
No indication of charging is shown.
A. If the Headset battery is empty or has not been used for a long time,
it may take some time for the Headset LED indicator to show charging
status with a steady Red light. Make sure the PLAYSTATION 3 is turned
on. The 8860 cannot charge without the console being turned on.
Q.
No sound can be heard from the Headset.
A. Please make sure of the following:
-Make sure that the two devices have
been paired.
-Make sure that the Headset is turned on.
-Make sure that the two paired devices are within 30 Ft. (9.15 meters)
of each other.
*** Do not try to pair the headset to
the PLAYSTATION 3 when the headset is attached to the USB cable. If it
is attached to the USB cable when trying to pair up, it won't pair with
the PLAYSTATION 3. ***
Hope it helps
You have to pair it with your PS3 or another device through BlueTooth.
even when:
cable.
and Red.
Trouble
Shooting
Q.
Q.
use.
Q.
Q.
been paired.
of each other.
*** Do not try to pair the headset to the PLAYSTATION 3 when the headset is attached to the USB cable. If it is attached to the USB cable when trying to pair up, it won't pair with the PLAYSTATION 3. ***
In order to use it you have to pair it with the PS3.
even when:
cable.
and Red.
Trouble
Shooting
Q.
Q.
use.
Q.
Q.
been paired.
of each other.
cable.
and Red.
Trouble
Shooting
Q.
Q.
use.
Q.
Q.
been paired.
of each other.
Hope it helps:
even when:
cable.
and Red.
Trouble
Shooting
Q.
Q.
use.
Q.
Q.
been paired.
of each other.
even when:
cable.
and Red.
Trouble
Shooting
Q.
Q.
use.
Q.
Q.
been paired.
of each other.
