Question about Frigidaire FAC127S1A Air Conditioner
Control panel is not working - Frigidaire FAC127S1A Air Conditioner
Posted by steelgrid on
Electrolux
  • Official Brand Answer
  • 4,342 Answers
Does this unit have a remote? If so, try to use it, does it work then? If not, then the control board is most likely your culprit. If it does work, then possibly a button on the control panel is faulty.
Posted on Jul 24, 2012
Bravo 2012 gas dryer control panel
I have the same dryer. My control panel went dead today too. Light in drum works just fine. Nothing working at all on the control panel.
Mar 07, 2014 | Maytag Bravos 7.0 Cu. Ft. Gas Dryer
Display panel control
I had the same problem with my Maytag range. I pulled out the stove and unplugged it. I took off the back panel that protects the digital panel that controls the oven. There was dust all over the electronics. I got a can of compressed air that is used for computers and blew all of the dust out. Plugged the stove back in and it has been working fine since then. Dust can create static electricity. The replacement panel is $300, plus labor.
Nov 28, 2013 | Maytag MER6769 Gemini Electric Kitchen...
The control panel isn't working properly. How do
Try getting in through the start menu, your documents, and your search bar. If all fails, then start your computers command prompt, (type in search button in start menu: "cmd") just type in: "start control" and press enter; the control panel will launch. Also, if you type "run" in your start menu search bar and type in control followed by pressing the enter key, the control panel should start up.
Jun 22, 2013 | Computers & Internet
The setting push panel does not respond - can't turn it on
follow this steps and fix it. God bless you
Touchpad and Control Panel
If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board
The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been ruled out, the main control board might need to be replaced.
Jun 14, 2013 | Dishwashers
Regency problems
Enter your model number to see parts for your dishwasher.
Help me find my model number
Touchpad
Main Control Board
Jun 14, 2013 | Maytag Dishwashers
My leisure dwlt65 dishwasher keeps switching its self off when going till wash
see this causes and fix it. God bless you
Touchpad and Control Panel If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been have ruled out, the main control board might need to be replaced.
Sep 28, 2012 | Leisure DWLT65 Dishwasher
I have a whirlpool electric glass top stove (model # rf364pxpq ). our electricity went out for only a moment, and when it came back on, the control panel is blank and the oven doesnt turn on. the stove top...
I just encountered the same problem. Power surge during storm caused the control panel to go blank. I removed the panel to get the part number. Reinstalled control panel and it started working. Below are the steps 1) Turn off breaker 2) Unplug unit 3) Remove rear panel 4) Unplug all connections to control panel 5) Wait 5-minutes 6) Reconnect all wires in reverse order 7) Install rear panel 8) Plug in unit 9) Switch breaker to on position Control panel came on, set clock and all oven functions worked.
Jan 02, 2011 | Whirlpool Kitchen Ranges
The controls that turn the tv of and on no longer works
Hi,from your problem it can be concluded that the problem is from the control panel,as a result of this all the controls of this unit will fail to function.
The correct solution is to replace the whole control panel which holds this control,you can purchase the control panel from www.retrevo.com or www.evertek.com
Thanks and take care
Jun 24, 2010 | Soyo DYLT032D 32 in. LCD Television
My xerox phaser 6300 control panel is blank and was working
Your control panel is bad and needs to be replaced, here is a video to show you how.
and here is the part (click here)
Mar 15, 2010 | Xerox Phaser 6300DN Laser Printer
Frigidaire FAC127S1A Air Conditioner Logo
493 people viewed this question
Top Frigidaire Heating & Cooling Experts
Mike
Harjeet s. bola
Harjeet s. bola
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
