Iriscan Express 2 Flatbed Scanner Logo
Anonymous Posted on Jul 21, 2012
Can't get the driver for it
fanaudi
Level 3:
  • Iris Master 1,381 Answers
  • Posted on Jul 22, 2012
fanaudi
Iris Master
Level 3:
Answers
1381
Questions
0
Helped
294812
Points
4199
Hi Richard .
This driver should do the job : http://www.irislink.com/c2-1741-189/Drivers.aspx#2
Regards ,
fanaudi .
Webcam stopped working
you are installing the wrong drivers.. try slim drivers. it's an excellent program for updating drivers and it's FREE... Slim Drivers
1helpful
Code-28 driver acpi compliant system
right click on the driver with error and uninstall it. Restart your computer to install the generic drivers. Usually, computers generate their own generic drivers for the hardware parts in your computer. After doing that, update all drivers. You can find the updates in the website of the manufacturer. However, if you would like to get the correct drivers in no time then you can use RadarSync.
David
2helpful
2answers
My transcend MP330 is not gettin recognized by the computer..
1) Turn on your mp3
2) go 2 settings>MTP thn select MTP
3) connect 2 a pc
then you'll see it as a portable device
4) FORMAT IT
5) go 2 settings>MTP thn select USB [on ur mp330]
3helpful
2answers
Missing ATK0100 driver for asus K52J
I'll recommend you to directly try Driver Detective and let the software have a free scan to automatically detect & update the missing ASUS drivers. This way things can be much easier & efficient. Also you don't have to risk install wrong drivers which might cause severe system issues. Regards!
I need a wireless lan driver for my toshiba c660-c660d from the above list at this url http://aps2.toshiba-tro.de/wlan/?page=downloads
Hello liharris2011,
I've given you a "Link to the Website, where you can,
"Download the Drivers that you need."
First, make sure that the you 'Enter' the "Operating System."
eg: Windows XP, Vista or Windows 7?
There will be an {Drop Box}, to choose from!
This way, you'll be able to get the right "Drivers."
Scroll down, to find the (Number list).
The "Drivers you need is on the #(2) page!
The 'Driver that you need are the "Realtek LAN Drivers."
Next, download the [File].
Find the {File, and "Install the Driver"}.
"Restart the computer, so that the configuration can make the 'correct' changes.
If you need help with anything else?
"Write a 'comment'; I'll be here to assist you!"
"Best Regards"
Click here for "Drivers" http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2786686&rpn=PSAX3U&modelFilter=&selCategory=2756709&selFamily=1073768663
3helpful
Inverted web cam display in asus k401j
1. Download the latest Chicony (or Suyin) driver for Windows 7. Check here: http://support.asus.com/Download.aspx?SLanguage=en&m=Camera&p=3&os=)
2. Extract contents to desktop.
3. Click the ORB button. right-click on Computer and select Properties.
4. Select Device Manager.
5. Click on Imaging Devices to show the name of the webcam.
6. Right-click on the name of the webcam and select Properties.
7. Go to the Driver tab. click on Update Driver. a new window should pop-up.
8. Click 'Browse my computer for driver software'. select 'Let me pick from a list of device drivers on my computer'.
9. On the next window, it'll give you the current driver. click 'Have Disk'. click Browse. Browse to the desktop and select lastest driver that you've downloaded. it'll be then added to the list of drivers. select the new driver and click Next. Just follow the prompts so that it'll install the new driver.
If still this does not work, try this:
Re-install the camera virtual camera using your ASUS hardware disc and follow this step.
1.Insert ASUS hardware disc and "open"
2.Click "explorer"
3.Click "software"
4.Click "camera", then choose and click chicony folder
5.Open the folder APPLICATION/installer, and re-install the ASUS virtual camera.
Once you already installed the driver, go to start menu click or type ASUS lifeframe then open it.
My laptop has had a complete memory boot and i can not get my wireless connection back on. How do i correct this problem/ i am using a ethernet cable at the moment to get connection to internet. Thank you
Improve the Fixya.com experience for everyone by voting!
The first solution I'm suggesting works in my business (LAN installations) about 95% of the time. I trust that it will work for you.
Let's see if I can help you.
Begin by turning on your computer and your router
? Make sure your service provider has activated your account and services on the subscribed line. Please check with your service provider to confirm this.
? Make sure that you are using the latest drivers. You can download the latest driver from Driver Downloads Database.
? Make sure that you have entered the right username and password (case-sensitive) as given by your service provider. For example, in Australia: user@bigpond; in NZ: [email protected].
? Open Internet Explorer;
? Click on 'Tools';
? Click on 'Internet Options';
? Click on 'Connections';
? Click on 'Setup'
? Click on 'I want to set up my Internet connections manually . . .';
? Click on 'Next';
? Click on 'I connect through a local area network (LAN);
? Clock on 'Next'
? Click on 'Next' [This is not an error];
? Click on 'No';
? Click on 'Next';
? Click on 'To connect to the Internet immediately . . .; and,
? Click on 'Finish'.
That should have you online. However, if it doesn't get you on line, do the following: Click on tools again. Click on 'Diagnose Connection Problems' and follow the instructions.
The last choice is to use the Setup Wizard. It seldom works for me but you might more luck than poor me. Here are the instructions:
The Connect to the Internet wizard will guide you through the steps of setting up an Internet connection.
Open the Connect to the Internet wizard by:
• Clicking the Start button Picture of the Start button
• Click on Control Panel.
• In the search box, type network,
• Click "Network and Sharing Center"
• Click Set up a new connection or network
• Then double-click "Connect to the Internet".
All the best
Ben
Top Iris Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Iris Office Equipment and Supply Expert? Answer questions, earn points and help others
