HP Photosmart 945 Digital Camera Logo
Question about HP Photosmart 945 Digital Camera
Hp photosmart 945 will not read memory card
Memory card error
5 Related Answers
Anonymous
SOURCE: won't read sd card - says card not suppoorted
Did you try putting the card in the camera, and using the camera's "format" card option?(Make sure there is nothing on the the card-a format will delete it.) Often times, a digital camera requires a format of the card so the proper file/directory structure can be created. If the card is empty, you have nothing to lose.
Posted on May 21, 2007
Inky
Inky Fingers
  • 705 Answers
SOURCE: HP photosmart D7300 series, will
Card format may be incompatible with reader or card may be too large for reader to manage. Try another card in the reader to see if it will read that one. If so you know the card is the problem not the reader.
Posted on Sep 19, 2008
Anonymous
SOURCE: Error reading SDHC flash card in a HP Photosmart 8250 printer.
Purchase a SDHC to USB media converter (e.g. SanDisk
M/N SDDR-113-A10M), which allows you to plug that SDHC
memory card into the printer via the USB port.
Posted on Mar 14, 2009
Anonymous
  • 423 Answers
SOURCE: My HP Photosmart R707 Camera not reading memory cards
If the memory card you are using is an SDHC designated card, your camera is probably not compatible with it. SDHC cards are usually 4gb and larger. Check the card for the SDHC label.
Posted on Apr 04, 2009
Anonymous
  • 788 Answers
SOURCE: hp m517 camera memory problem
YOU WILL HAVE TO FORMAT THE NEW CARD AND RESET YOUR CAMERA TO FACTORY SETTINGS.
If you BING the m517 it will give you all the specs. you need.
If you go to hp.com on the first page look for trouble shooting a product. Type in you m517 and you will get all the required info.
Hope this was of some help to you.
Readers, please rate your technician's information.
Thanks,
John Ray
[email protected]
Posted on Jul 13, 2009
945 card is unreadable
What type and size memory card?
PNY Optima SD HC Card cannot be read in HP Photosmart 8150 printer.
  1. Verify that the printer is turned off.
  2. Remove the Secure Digital memory card from the printer.
  3. Examine the Secure Digital memory card:
    • Is the lock switch in the unlock position?
    • Are there any visible discolorations or defects such as crack or nick in the card?
    • Are there any contacts missing from the end of the card?
    • Are there any deep scratches in the card contacts?
    • Is there any heat discoloration on the card? NOTE: If all of the above questions result in No , proceed to Step 4.
  4. Check if the HP Photosmart printer supports the file format. NOTE: In order to know which file formats are supported by the different HP Photosmart printers, please refer to the manual of your printer.
  5. (Saving the pictures on the PC, if possible) Insert the Secure Digital memory card in the camera (or another device) and format it following the proper instructions to perform it.
  6. Capture an image.
  7. Review the image. If the image is corrupted or an error such as Unsupported Image File is displayed, the Secure Digital memory card is suspected to be defective and should either be replaced or referred to the manufacturer for further troubleshooting.
  8. If the images are read properly, turn on the printer. Insert the Secure Digital memory card in the Secure Digital slot.
  9. If the printer display continues to show the Card Not Recognized error, try using another Secure Digital memory card, if one is available.
  10. If the printer is still unable to read a functional and compatible Secure Digital card, contact HP to obtain additional troubleshooting information.
1helpful
Does Hp 945 work without a memory card
Yes, but the camera has only 32M of internal memory so you won't be able to take and store more than a handful of pictures. For "real" use you'll need one or more SD cards. Make sure you get SD cards 2GB and smaller, not SDHC cards.
2helpful
I got a 4gb memory card-SanDisk and the camera says it is unreadable.i had a 512mb card and it worked fine.
Hi Tomcat,
this will not work.
The HP 945 does not support 4GB cards.
4GB (or more) are SD-HC (High Capacity). This is new format which only will be supported by newer camera models.
1helpful
3answers
Hp photosmart 2610 won't read my sandisk ultra memory card
Previous solution is the FAIL. Original poster says it works fine in _camera_, but not in _printer_. _Printer_ is the compatibility issue, not camera.
Memory card error
Memory cards larger than 2 GB are not supported with Photosmart printers
Hp 945 Digital Camera
hi there, try another SD memory card, i had the same problem.. but then i bought a new card and the problem was solved... best regards, Richard.
HP Camera won't turn on
I had the exact same problem. I turned on my HP Photosmart E317 camera and it would light up for one second and then just a blank screen. Here's the tech support site from HP. Try taking out your memory card and then turn it on. That worked for me. I just put the memory card back in and it works fine. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00709691&lc=en&cc=de&dlc=de&product=445953&rule=2137&lang=de
Top HP Cameras Experts
Lawrence Oravetz
ADMIN Andrew
ADMIN Andrew
Are you a HP Camera Expert? Answer questions, earn points and help others
