Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Error C11A3 Konica Minolta BH 350 - Konica Minolta bizhub 350 All-In-One Laser Printer
Posted by hasanat on
Mark Marcoso
    New Friend:
Solution for error code c11a3 konica minolta bizhub 350 machine
Posted on Dec 26, 2013
5 Related Answers
hamzaskilltd
amir hamza
  • 318 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
steven brickhouse
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
Anonymous
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
Posted on Mar 08, 2010
herminio_hal
Herminio Halili, Jr.
  • 210 Answers
SOURCE: How to setup scan to pc on Konica minolta bizhub 350 Error ED09C7
Your configuration sharing SMB folder is incorrect. Create desktop folder rename all upper case SMB right click on the folder and click sharing and set full control to everyone. Go to web brouser type in the ip address of the printer log on to administrator password 8 zeros or 12345678 and change the setting.
Posted on Jul 09, 2009
Anonymous
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Nov 19, 2007
Monolta izhub 362 hwo to reset drum counter
Bh 362 is the upgrade of Bh 200, 250 and 350 and on that model you need change drum and developer together. The drum counter message can be reset in service mode by a qualified tech after replacing those parts.
Aug 23, 2014 | Konica Minolta Bizhub 362 Copier
How do I clear the error code C11A3?
Shutter unit defection.Press Utility key-Meter count-Check details-00000000-End and you entering in service mode,select trouble reset.The very simple method is remove the finisher/exit unit and work without.
Aug 05, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
How reset konica minolta bizhub 350 ?
reset what on the bh 350
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 19, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Code erreur C11A3
model number
Mar 17, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Konica minolta Bizhub c250 code erreur c11a3
finisher issue the output tray there are four orange roller if they are clean!!!!!!!!! that opening between them is causing a issue
Feb 06, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Error code c11a3
your top output tray in the middle are four orange rollers when properly cleaned. well the top two and bottom should seperate when paper comes out, there is a problem with that get a tech out to look at it.
Error code C11A3
C 11A3 Shutter unit problem.Verify the paper exit unit.
Jan 11, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Error c-3E05
what model no code for the bh 350
Dec 17, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
1,547 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
