Question about Maytag Quiet Series 300pan Dish Rack 99002728grey
Heated dry cycle light on
There is also a flashing L on the front of the screen where normally it would display time left in the wash cycle., and it's not specifically the heated dry button, but the light in the weird boxed 3 just to the left of it is lit. I can't make this light go off or start my cycle. I've tried canceling/starting it and just selecting my cycle for it to run, nothing is making the light go away or the dishawasher start.
    Top Expert:
  • Maytag Master
  • 12,223 Answers
See the cause and fix it:God bless you
Failure Code Condition Check/Repair "L" persists in washer display Lid lock failure Replace switch, linkage, lock solenoid or control board.
Posted on Jul 21, 2012
2 Suggested Answers
6ya staff
SOURCE:
bigvic36
SOURCE: My Maytag steam dishwasher # MDBH980AWS won't do
My Maytag dishwasher # MDBH950AWW wont turn on no light but it has power in the outlet no power to the control board
Posted on Jan 21, 2010
My washing machine will not turn on.
I suggest you rapid reading of alarms.
  • Press the START/PAUSE button and the nearest option button simultaneously for at least 2 seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
  • To display the previous alarms, press the button to the left of the START/PAUSE button in sequence.
  • To return to the last alarm, press the START/PAUSE button.
  • The alarm continues to be displayed for the amount of time required, and then the display returns to its normal operation.
  • While the alarm is being displayed, the appliance continues to perform the cycle or, if in the programme selection phase, it maintains the previously selected options in memory.
Dado
Dec 09, 2015 | Electrolux Washing Machines
My Whirpool Duet front loader will begin a wash cycle, but stops when cycle switches to rinse with water in the drum. Door remains locked & light by the 'wash' flashes 9 times...
when the machine is stopped can you empty the residue water that remains by the programme selector? if not check for blockage in the pump(coin), the hose internal blockage ,or at the outlet under sink. I hope this help
Jan 15, 2015 | Whirlpool duet Washing Machines
My swan 2030b washing machine won't finish the cycle
This displays and error and it can be possible that the inlet flow is low, the inlet filter is clogged or the drain is faulty all of which can reduce the fill/drain timing and so causes an error..
Please remove and clean the filters and check the inlet flow pressure..
Mar 23, 2013 | Washing Machines
Washing cycle timer display slows/stops
sound like the pump is at fault still it might still work but it sounds like its an earth fault with the pump but some time by replacing it don't all ways work its normally the board at fault as well an expensive job OK
Nov 03, 2012 | Whirlpool AWOE8748 Front Load Washer
Everytime i put my washing on it goes onto test mode. I reset it so it is back to the on screen and then evertime i press a cycle it goes back onto test mode. Ho9w can i get it out of test mode and back to...
You will have to look at the manufacturer's plate, probably on the back of the machine to find the appropriate date then-
Date code 39, March 2005
Press start/cancel until ALL LEDS are lit
Press both start/cancel AND on/off together until 'dOFF' is displayed
Date code 39, March 2005 to date code 42, June 2005
Press the cancel button and the machine should return to normal
Date code 43, July 2005 onwards
Press both start/cancel AND on/off TOGETHER with top left option button until 'dOFF' is displayed.
Good luck,
John C
Apr 01, 2011 | Hotpoint Ultima WF860 Front Load Washer
I have a Kenmore Elite HE 4t front load washing machine. Code F ud is currently flashing and the door won't open. I've tried canceling but it just beeps and keeps flashing this code.
Remove the bottom panel. The tech sheet is located beside the white box to the left.088d3fc.jpg It gives diagnostic directions and failure codes. Suggest you clean the dispenser area up04f0b28.jpg and use the correct amount of HE detergent.
Seems to me like that is a suds detect:All front load washers require "HE" detergent (a low suds type detergent).
There are three commonly sold concentrations of HE type detergent.
HE : (2) Tablespoons Per Wash Load
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated) : (1) Teaspoon
Most consumers follow the directions on the bottle or box of detergent--which is normally the correct thing to do. However, the amount recommended in nearly all brands of HE detergent are excessive & incorrect.
Additionally---using the correct amount of HE detergent will end issues with:
1) Musty Odors
2) 'LE" Errors (that can cleared by unplugging the washer)
3) L-O-N-G cycle times (longer than time displayed).
A 51 minute cycle can take 120 minutes to end.
4) Insuffificent Cleaning Results
5) Small water leaks behind the washer at the air vent.
(Suds oozes out during the spin cycle)
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 19, 2010 | Kenmore Washing Machines
"HO" flashes on display during washing.
HO, indicates that the dishwasher is using Hot Water. It is completely normal.
Mar 08, 2009 | Frigidaire Professional Series 24 in....
F flashing followed by a 2
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Feb 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer stopping mid-cycle with no error
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you have drained, unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out. F-21 filter blocked.
How abt a nice rating for the free help?
Jan 04, 2009 | Whirlpool GHW9300 Duet Washer
Maytag Quiet Series 300pan Dish Rack 99002728grey Logo
130 people viewed this question
Top Maytag Dishwashers Experts
Mike
Marvin
Marvin
Vitally Alcher
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
