Question about Kodak EASYSHARE 5100 All-In-One Printer
All photos have a green tint
Running Mac OS X 10.5.4 Printer is Kodak EasyShare 5100
All photos, even B&W, have a green tint.  Changed ink cartridges, rebooted and calibrated printer.  Used different computer running Vista.
Same issue no matter what.  Appears to be a printer issue.
Posted by mitch_presle on
  • fcswife Feb 28, 2009
    I have teh same issue, but it's a "pink" tint.
  • lilblu81 Feb 28, 2009
    same but pink tint
Vladimir Frolov
  • Kodak Master
  • 2,075 Answers
Try to factory reset the printer
Posted on Jan 25, 2018
5 Related Answers
Anonymous
  • 14 Answers
SOURCE: prnter kodak easyshare 5100
just to check, is what specific lights is blinking is it the check color or just check black inks??
-to make sure w/ this one is it blinking too fast or slow and what is the color?? check if the on and off is also blinking
-check black ink and check color cartridges blinking fast means no printhead installed
-check black ink and check color cartridges blinking slow, no cartridges installed
-check black ink and check color cartridges blinking w/ on and off ready to calibrate
(in ready to calibrate if doing nothing, just press cancel and
-press photo and cancel on printer, if not doing anything
-remove printhead( the one that holds the cartridges) turn printer on and off, put printhead back to printer w/ cartridges, and check the lights that is blinking
-press photo and cancel again
-if not doing anything, contact manufacturer
-goodluck
Posted on Apr 11, 2008
Anonymous
  • 214 Answers
SOURCE: KODAK EASYSHARE 5100 SERIES
a blinking yel light w/ "F" on display means MEDIA SENSOR FAILURE
"P" PRINTHEAD FAILURE
"S" SCANNER FAILURE
Posted on Apr 22, 2008
Anonymous
SOURCE: Kodak EasyShare 5100 All in one printer
I just called them yesterday and a new printhead should be on the way
Posted on Sep 05, 2008
Anonymous
Blow the printer up. This is a on going problem that they can't or wont fix. I'm on my 23rd printhead and wasting alot of ink, paper, and time.
Anonymous
SOURCE: My printer will not print anything.
Contact Kodak support from the Kodak webpage. Do the chat online. Sounds to me that it is the printhead. They may find that the printhead needs to be replaced. I did it today and they are sending me a new printhead plus spare ink cartridges for free (2-3) days.
Posted on Dec 23, 2008
When printing a photo has a yellow/green tint. All other functions work it prints and scans great. Just have a problem with printing photos.
Possibly it is running low on Blue ink - because colors are usually a mixture of inks - for example green is made from blue and yellow - if an ink runs low it will print the available colors or substitute the next available color.Probably if it prints green yellow - then it has no blue available to make the right shade.
Oct 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Bought a new ink cartridge for 5300 printer - all photos were purple. Replaced ink cartridge with another new cartridge and now photos are green/yellow.
problem with printhead. go to www.kodak.com/go/printheadsupport and then try to remove printhead from printer. put it back again into carriage,install cartridges and then clean printhead from home center software. u r issue will be resolved
Jul 28, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
My Kodak 5100 printer has been great. Even though
Clean the printhead, then print a demo sheet.
  1. Verify that inkjet paper is loaded in the paper trays.
  2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
  3. From the Help menu, select Maintenance, then select Printhead Cleaning. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows a steady green, press Photo and Copy simultaneously to print a demo sheet.
Is the Demo printout giving the same result?
If so, you may need to replace the printhead. This is a very common problem with this model.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 03, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Both Ink Lights Keep Flashing
You might have a printhead problem. Call 1.800.421.6699 to get a new one.
Feb 26, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Red tint on pics
I am not an expert with Zodak but you can go to their website and they have a solutions and repair section hope this helps you.
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=10/7895&pq-locale=en_US
Jan 28, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Can print paper but photos have green tint
If you refilled the ink cartridges, this can happen. Kodak uses pigment based inks, the others use dye based inks. Also, make sure your printer is set for normal photo printing, rather than special effects.
Jan 01, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Redish tint on pictures
your printhead needs to be replaced because, most likely, the jets that shoot the ink got blocked because of the remaining ink from your last printing session.
Just go ahead and go to kodak.com/go/itg , follow the troubleshooting and have your printhead replaced, or call their support center on 1 800 421 6699, and have them help you out.
Nov 23, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Color is all wrong
Your pictures are coming out with a blue tint. Remove the color catridge and look at the bottom of it. the Yellow is probably green. If it isn't, trying performing a printhead cleaning through your home center. After that, calibrate the printer, you may see that on the calibration sheet, that colors are missing. Scan the calibration page and then try your printing your pictures. If that doesn't work, contact kodak tech support, you need a new printhead.
Sep 03, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Photos are printing green
call support and have your printer head replaced
Jun 01, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Prnter kodak easyshare 5100
-goodluck
Mar 13, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
80 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Ekse
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
