Question about Dell Inspiron 530 Desktop Computer
DELL E520 BLACK SCREEN ASKING ME TO ENTER BIOS PASSWORD
Posted by saleem aijaz on
Computer Repair Services
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 144 Answers
Hi, just set your bios settings into CLR CMOS to clear your cmos settings and to default your settings into factory settings.
Posted on Jul 24, 2012
4 Related Answers
Anonymous
  • 2600 Answers
SOURCE: reset system password jumper on motherboard
Posted on Sep 27, 2009
proton77
Mandeep Singh
  • 1183 Answers
SOURCE: 8200 Dell Dimension Password
HI,
Follow the instructions , on the link below , to clear forgotten passwords
http://support.dell.com/support/edocs/systems/dim8200/syssetup.htm#1104690
Thanks
Proton
Posted on Jan 30, 2009
Anonymous
  • 191 Answers
SOURCE: what is the password?
Assuming you are not connected to a network say at the office.
This looks like the BIOS password has been set. This is done by launching the BIOS setup and then enabling the system password feature.
Most systems you can press F2 to get into the BIOS or system setup at the moment you see the Dell logo. (This access key may also be displayed on the logo page, if it is not F2).
Posted on Oct 05, 2009
Brandon Arnold
  • 17 Answers
SOURCE: Can the bios on the Dell E520 be unlocked to
No, factory shipped computers are made so that they cannot be OC'd because this would void the warranty and be a nightmare for a companies HR department when people ruin their computers and demand that they be compensated.
If you are doing anything that would require overclocking I suggest you build a cheap computer for $400 - 600 in order to experiment.
Posted on Aug 21, 2011
Dell latitude D610. Bios Revision AO6 Anyone Help?
try to remove bios battery on the inside and short the pins with something iron like a screwdriver for a few seconds, remove the battery pack too when doing this, you should be fine after that,
ps. you might need to set some bios parameters when starting up again
Nov 03, 2016 | Dell Computers & Internet
Hi my name is Christine and I just got a Dell dimension E520 from my aunt. When I went to turn on the computer the screen came up with this saying: type the system password and press enter. My aunt and I...
If the machine is looking for the Dell BIOS password, then you can try entering a backdoor password of either Dell or lleD (case sensitive) which sometimes works. If not, you will need to enter the BIOS and reset the password to none.
Oct 05, 2014 | Computers & Internet
How can I reset bios password on asus notebook ?
bios password reset methods depend on model & how its designed,
in laptops cmos battery reset will not remove bios password.
you can reset bios passwords by:
1. Entering master password, if it shows password disabled with Error CODE after failed attemps,
2. shorting bios reset jumper located anywhere near the ram slots in motherboard
3. Re flashing the Bios Chip
Jun 21, 2014 | Dell Inspiron 1000 Notebook
My dell desktop asking for a password
If you want to create a new Basic Input/Output System (BIOS) password on a Dell Optiplex 745, reset the password. Resetting the password also applies if you want to remove an existing BIOS password. BIOS passwords are used to add an additional level of security to your machine. Without the correct BIOS password, your Dell Optiplex 745 will not complete the boot process. The password can be reset whether you know your current password or not.
Turn off your Dell Optiplex 745. Start the computer. Press "F2" the moment the Dell logo appears on the screen. You will only have two to three seconds to press the key. Enter your BIOS password. Navigate to the "Exit" screen. Select the "BIOS Password" setting. Enter your BIOS password and a new password if desired. Do not enter anything in the "New Password" box if you want to remove the BIOS password completely. Press "Enter" to save your password settings. Reset Forgotten Passwords Turn off your Dell Optiplex 745 and remove the power cord from the computer. Disconnect any external hardware and cables. Slide the release latch located on the back of your Optiplex 745. Lift the cover as you slide the latch. Hold the cover firmly and pivot it back on the hinges. Remove the cover from the hinges. Find the "PSWD" jumper on the motherboard. This is a two-pin jumper and should be clearly labeled. Use a flashlight and magnifying glass if you have trouble locating it. Remove the jumper from the motherboard. Replace the cover and slide it into place until the latch snaps into place. Reconnect the power cable and restart your computer. Shut down the computer after it has completely restarted. Disconnect all cables and remove the cover again. Replace the PSWD jumper. Replace the cover. Reconnect all cables and restart your computer.
b> Clearing forgotten passwords http://phubner.eng.ua.edu/Files/Optiplex 745/advfeat.htm - wp1117484
Mar 20, 2013 | Dell OPTIPLEX 745 PC Desktop
My dell monitor screen, s2209w, is blinking and asks for password
Check in in the BIOS,(Press F2 key during the start up) if the same thing u see in than BIOS replace the monitor.
Aug 01, 2010 | Dell S2209W Monitor
Black screen ask for password
Black screen with "Enter Password" in blue box. - BIOS password.
To reset: take the CMOS battery out then place it back again.
Black screen with Enter password in the upper right left corner - could be hard disc password.,
If you set up the password before, you can only bypass that by entering the correct password. If not, it will render the hard disc useless.
Jan 30, 2010 | Toshiba Satellite A55-S1063 Notebook
Black screen with blue box asking for password
that happened to my hp....some kid came to my house and stayed for the weekend...i don't know what the heck he did but i have a blue box as well and the password happens to be "password"....i don't know how i figured it out either...try it...it could work for yours as well!!! I would like to know how to get rid of it
Oct 28, 2009 | Dell Inspiron 1000 Notebook
Black enter password screen, but no password
I'm not sure if this will work but it may be that your system bios is asking for a password. If so, as you reboot the system, press F8 down until the system bios screen appears. Then page thru to see if the bios is asking for a system password. If so, you should be able to deactivate it thru the bios.
Hope this works.
Apr 22, 2009 | Computers & Internet
Bios remove password
How to clear an unknown BIOS password. Information and help with clearing an unknown BIOS password. ... On the computer motherboard locate and remove the CMOS battery .
Good Luck/Please dont for get to Vote.Thank You.
Dec 15, 2007 | Dell Inspiron XPS M140 Notebook
Dell Inspiron 530 Desktop Computer   Logo
244 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
