Question about Polaroid Battery Grip for Canon EOS-7D with LCD Display - PLGR187D
Where has the replacement battery CR1620 must be placed?
I need to replace the battery CR1620 in the battery grip but I cannot find the place where this battery is located
Posted by sergio on
  • sergio Jul 22, 2012
    also is there any support from Polaroid for this Battery Grip? I wrote to the address indicated on the small leaflet that name with the product but apparently the email address is not anymore valid
JimNKing
    Problem Solver:
  • 5 Answers
1) Open the main battery compartment
2) Remove the battery tray
3) Inside the battery compartment directly behind the LCD screen there is a small cover about the same size as the CR1620.
4) Remove the cover
5) Replace the battery
6) Replace the cover
7) Replace the battery tray
Posted on Dec 27, 2014
My calculator uses cr1616 or cr1620 coin battery. i was wondering if i could use a cr2016 or cr2025 instead.
The CR1616 and the CR1620 is a different size then the 2016 or 2025 The CR1616 is 1.6 mm diameter by 1.6 mm height the 1620 is 1.6 mm wide by 2.0 deep either of these will fit the TI-83 plus calculator and since the CR1620 is slightly larger it lasts about 20% longer. The diameter or the 2 batteries you mention is 2.0mm as that is what the first two numbers on the battery represent so it will be too wide to fit your calculator... The second set of numbers on the battery is the depth or height of the replacement battery... Best of luck
Feb 21, 2011 | Panasonic CR2016 Lithium Coin Battery
Tip
Nokia battery
<b>Remove the back cover</b><br /> Place the phone with the back of the phone facing you. Pull up the back cover from the finger grip at the top of the cover.<br /><br /><b>Note:</b> Always turn off the power, and disconnect the charger and any other device, before removing the cover. <a></a><span>Avoid touching electronic components while changing the cover.</span> Always store and use the device with the cover attached.<br /> <b>Remove the battery</b><br /> After you have removed the back cover, insert your finger into the finger grip, and lift the battery from its compartment.<br /> <b>Replace the battery</b><br /> <ol> <li>Insert the gold-colored contact end of the battery into the battery slot. </li> <li>Push down on the other end of the battery to snap it into place. </li></ol> <b>Replace the back cover</b><br /> Place the back cover on the phone bottom first so that the cover tabs align with the slots in the phone and press the cover moving from the bottom to top until the cover is securely in place.
on Mar 09, 2011 | Cell Phones
I need to know how to change the battery. Can you send a manuel.
Printed instructions for battery replacement are not provided by the manufacturer.
You will find batteries for model ES-1000 at shaveroutlet.com. See link below (you will need 2 batteries)
http://shaveroutlet.com/shaver-replacement-parts/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
To open up the shaver, gently pry off the rubberized grip on the front with a small flat screwdriver or similar. This will reveal 2 screws at the bottom. Remove the screws and the flat plate under the cutters that clips on there. You can then gently pry apart the two halves.
You can then access the batteries, remove the old ones and solder the new ones in place
Oct 18, 2010 | Remington ES-1000 Electric Shaver
Hi I have got casio babyg 163 model.i believe it needs battery replacement but cant find the battery model any help plz
mcdevito75 here, Best Bet, look for a small watch repair shop in your area to cahnge the battery as any pressure on the display while changeing the battery on a Casio watch will break it.
Jul 03, 2010 | Casio BG163-4V Wrist Watch
Samsung camcorder SMX-F34BN. Need to replace hand grip. Have replacement part, but do not know how to remove old and replace. Help
Follow the steps to replace hand grip :
Remove two screws near battery
Remove the tiny screws on each side of the hand grip release.
Once screws are removed, gently prise of button. Do not attempt to remove the lever.
Remove the four screws holding the eyepiece in place.
Once the four screws are removed, pull out the eyepiece, notice the button that operates the cartridge access.
On the top of the camera, using a pointed tool and light hammer, gently tap in an anti-clockwise direction.
Now slowly lift from the front, taking care not to damage the power zoom buttons on the other side, and slide towards rear of camera to remove cover.
With the camera facing you, remove screws below the lens, then gently remove the side cover above the hand grip.
Use a blade to scrap away glue around the two screw heads, then remove screws. Then, using a pointed tool, insert into one of the small holes, and using a light hammer, gently tap to unscrew the hand grip screw.
Thats it hand grip is removed . Now replace the hand grip and follow the above steps in vice versa .
Hope this helps .
Mar 29, 2010 | Cameras
What replacement backup battery does the pavilion
Hi, most motherboards that I have fixed etc... have used the 3.0V CR1620 Button Cell Battery which is easily available and cheap!
Jan 05, 2010 | HP Pavilion 515n (DC471A#ABA) PC Desktop
I want to replace the handle bar on my 2007 Honda CRF100. Where is a good place to buy the part and how do I rempve the grips?
Hello, Ebay would be a good place to look for them! Can get them Way cheaper there! Here is the trick to getting stuck grips off a bike without ruining them! Use Compressed air to remove them. Take the hose of air compressor 125PSI with a Blow gun attached to it. Now on the Flanged part of the grip put the blower end between the grip and bar and hit it with air. If it does not fly off gently twist the grip and it will most likely come right off! Here is another trick! Put them on in the reverse manner! To keep them in place I use Hair Spray Like Finalnet. It makes the grips go on easy and when it dries it will hold the grip on like Glue! Have a Good one!!
Remember Road Rash Hurts! So keep your Chin up!! Rick
Jul 08, 2009 | Honda CRF 150 F Motorcycles
Can't figure out how to change the battery
I believe your question is more to the point of "How do I get access to the battery so I can change it out?"
It's ugly, but not THAT bad.
Standing at the front of the vehicle, the battery is under the "electrical center" to your left, on the passenger side. You have to get some stuff out of the way to get to the battery...
1. Remove keys from vehicle
2. Remove the plastic shield covering the wiper motor and linkage along the top-left of the engine compartment. This shield is just held in place with metal clips.
3. Remove the stiffening strut on the left side. This is the large metal tube that goes from the left-rear corner of the engine compartment to the front of the engine bay, next to the radiator cap. 3 large bolts hold this in place, you may need a 1/2" breaker bar to loosen them, with a 13mm or 15mm socket. Slide the bar out of the "electrical center" (fuse box) and out of the vehicle.
4. Move the Electrical Center off to one side. Nearly all of the electrical wiring for the vehicle goes through this, so there are lots and lots of wires to shove out of the way. Make sure the main positive feed at the front of the box is insulated and won't touch any metal parts when you twist the box out of the way. You may want to get a bungie cord to hold the box off to one side. If you have to remove that main feed to get enough slack to move the box, remember that this cable end is HOT, don't short it to anything! Cover that cable end with piece of rubber hose or some other insulator.
5. Disconnect the Negative battery connection. This is the connection closest to the side of the vehicle. Usually uses an 8mm socket to loosen it. Whatever tool you use, make sure that you don't short it to the positive side of the battery.
6. Disconnect the Positive battery connection. There should be a plastic safety cap over the bolt.
7. Loosen the battery hold-down bolt at the base of the battery, between the two cable connections.
8. Lift the battery out of the engine bay.
Now, you know why you should buy a good quality battery for this vehicle. Buy a cheapo, and you'll pay for more hard labor. :)
Jun 29, 2009 | 1997 Pontiac Trans Sport
Tail light replacement
Hi Guys and Gals,
I figured out that there are two rubber grommets that hold the light assembly in place. Access to the grommets is easy as you just open up the taligate and you can see them located on the inside of the rear area of the van. All you do is take a pair of vise grips or a flat head screw drive and pull or pry the gromments our of their holes. ( I prefer using the grips, no slippage while prying) the old light will drop out of the slot. Remove the wiring harness from the old light as well as the light sockets, incert the sockets into the new light, replace the bulbs into the sockets, then re-connect the wiring harness. Place the new light into it's place on the outside of the vehicle and replace the rubber grommets. Close the tail gate and Voila, your done! Hope this helps some else.
Jul 12, 2008 | 2001 Dodge Caravan
Replace Battery Cover
to get to the battery door you must remove the back, to remove the back you must remove the top of the grip (shutter button and dial and WT lever). remove top of grip... 1) starting at the bottom of the plastic strip (along the front edge of the grip) that holds the shutter button, slide upward, the strip will bow outward and after about 3/16", the bottom's free. the only other thing holding it in place is a bit of double-stick tape and a similar clip at the top. CAREFUL! there's a spring under the button that's easy to lose. 2) Inside the battery case, front battery, all the way at the top, there's a tiny phillips screw, pull it. 3) peel away the right side rubber grip right by where your thumb meets the W on the W/T lever. 1st hole you'll see is a springy clip, keep going around to the right til you find a screw. pull that. 4) back to the springy clip hole, pushing inward on the finger, the top will come off straight up. leave it hanging, you just need it out of the way so the back can come loose. remove the back... 5) bottom of camera, remove 2 screws nearest the CE label and one outboard of the rearmost battery. 6) viewfinder cap: 4 screws, skinny on top, fatter on the bottom. the cap pops off. 7) lcd cover/frame: pull away from viewfinder(top) edge about 1/4 inch. the bottom's held by fingers; they need to slide to the left 1/8", then that's off. 8) remove screw @ lowerleft of lcd. now the whole back will slide rearward. 1st thing loose is memory door, remove it. slide the back off, out of the way. you'll now see that the battery door is held on by two hinge pins, not one continuous. the rearmost pin will slide left into the memory cover area, and the door will flex enough to remove it toward the front. trickiest part of reassembly is the spring under the shutter button. balance the spring on the camera, put the button into place. hold it in place with the screwdriver through eye of plastic strip, leaves plenty of room to seat the strip. lose a screw? I did, and the least-needed one is the one pulled at #3.
Oct 04, 2006 | Konica Minolta DiMAGE Z1 Digital Camera
Polaroid Battery Grip for Canon EOS-7D with LCD Display - PLGR187D Logo
322 people viewed this question
Top Polaroid Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
