Circuit board was changed due to beeping randomly but did not spin before the repair
SOURCE: Ge front load washer model WSXH208A Will not spin
Mine kept stopping mid cycle also, pouring water on the floor, then the start/pause button flashed and the door unlocked. I found the solution to clean the lint filter on the GE Adora. Go to
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
I just did this and my washer is now running instead of the flashing
start/pause and door unlocking. It was fairly easy. Make sure you
have towels and a flat pan to catch the water if you don't have the
machine on a riser. There may be water inside so a wet vac may be
helpful too. Once my washer finishes what was in it, I have these
funky towels to clean. You'll be very surprised what you find in the
filter! Best of luck!
SOURCE: Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
SOURCE: GE WSSH300G Front Load Washer drains, but
Door latch for that model I chrge labor and materials minmum charge is 180 ... its easy to replace ..2 minutes done...
have since checked filter, found two pennies still not spinning on delicate, quick wash or if put on spin
