Question about Cameras
I have a Samsung PL100 digital camera. I dropped it while at beach, it was switched off. When I went to switch it on the lens came out but then it made a buzzing sound and switched itself off. The lens is still out but the shutter cover is still open. I love my camera and take it everywhere with me, can you help?
Posted by ljtinkerbell on
annespiratio
I had the same exact issue.... try putting it on the charger, even if you think it's fully charged... If the light is red, leave it on the charger until it turns green, and then remove the battery for a second and then put it back in the camera before turning it back on..... try turning it on. If it still won't close, put it back on the charger. If the charger is automatically indicating a red light, that means you have exhausted your battery and will nee a new one... they cost about 5-11 dollars on amazon...... hope that helps...
Posted on Nov 20, 2012
5 Related Answers
Anonymous
SOURCE: Digital camera switches on and then off very quickly
I too am experiencing the same problem with this model. Have you found a solution? I think it could be a firmware problem, but I can not find a update download.
Posted on May 15, 2007
Dov Dror
  • 641 Answers
SOURCE: Frozen lens and shutter
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Posted on Sep 10, 2007
Anonymous
  • 3 Answers
SOURCE: HELP! dropped camera, lens won't go back in, shutter won't close
I have a camsung L830 that had similar problems and and after I would turn it on, it would beep three times and turn off....but I somehow fixed the lens by turning the camera on and then either pushing/pulling on the part the stickes out and hopefully it might activate the mechanism and it'll go in...that's what happened with mine...the shutters still won't close though. But I'm happy I can use my camera now.
Posted on Jul 26, 2008
darntoothysa
Thomas D.
  • 489 Answers
SOURCE: lens error restart camera but
Hi
Your lens is defective needs to be cleaned, repaired or replaced. If you got sand in the gears it will definitely jam up the lens! Sometimes you can tear down the lens and clean out the sand, and if none of the gears are damaged the lens will then work properly again.
There are online places that will do it for a decent price and there are others that overcharge by way too much.
I know this because I OWN ONE that charges a reasonable price to do the repair! (Google 'darntoothysam')
Just let us know if we can help! Good luck from
Darntoothysam com
Thomas
Posted on Oct 10, 2008
arclight1217
BRIAN REISS
  • 208 Answers
SOURCE: Digital camera got dropped into
THIS SOUNDS TERMINAL, BUT YOU MIGHT TRY USING CANNED AIR LIKE YOU USE TO BLOW DUST OUT OF YOUR COMPUTER, AND SEE IF IT HELPS ANY. MOST OF THESE CAMERAS ARE MADE WITH THE IDEA THAT THEY WILL NEVER BE TAKEN APART OR OPENED FOR CLEANING ETC. SO, THAT IS THE ONE PROBLEM YOU ARE FACING. I DOUBT IF IT WOULD BE WORTH SPENDING THE MONEY TO SEND IT IN TO BE CLEANED. THAT CAN GET VERY EXPENSIVE IN A HURRY, PLUS TAKE A GOOD MONTH OR MORE FOR THE REPAIR. SORRY, I CAN'T HAVE MORE CHEERY NEWS, BUT THINGS LIKE THIS JUST AREN'T TAKEN INTO ACCORD WHEN THEY MAKE THESE CAMERAS. IF I CAN HELP MORE JUST REPLY TO:
ARCLIGHT1217
Posted on Nov 04, 2008
Lost software for samsung pl100 how can I download
The downloads you need are at this link....
http://www.samsung.com/levant/support/model/EC-PL100ZDPBME-downloads
Jul 31, 2014 | Samsung PL100 DualView 12.2 MP 3x Optical...
Disassembling samsung pl100 camera
Did you look on ifixit? There you can find manuals, video tutorials and also spare parts, tools and more to repair your electronic equipment yourself.
Nov 03, 2013 | Cameras
Can I get a print-out manual for the Samsung TL205/PL100 Digital Camera
You may download the manual here. You can print it out yourself, or most office-supply stores can print and bind it for you.
Jan 24, 2012 | Samsung Cameras
My samsung pl100 wont turn on. the lens is extended and its fully charged the green light comes on then beeps and shuts off. This camera is brand new ive only had it 1 week! how do i fix it?
OK this might sound harsh but i just did this. I pushed in, gently with some force, on the lens while pushing the power button. It made a gawd awful crunch sound, but it worked. Good luck.
Dec 23, 2010 | Samsung SL202 Digital Camera
The lens is stuck out and is slightly bent and it wont switch on. the light comes on and then switches off. it was dropped
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Nov 02, 2009 | Samsung Digimax S630 Digital Camera
Lens stuck half way out
it seems that your cam and barrel assembly has been damaged. The worst part is that you do not get the spare part either from Samsung or any other vendor. if you get a solution please mail me
Aug 31, 2009 | Samsung Digimax V800 Digital Camera
Cameras Logo
162 people viewed this question
Top Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
