Proscan 42LA30H 42 in. LCD Television Logo
Michelle Posted on Jul 20, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Proscan tv volume problems
The volume turns all the way up and can't be adjusted
  • Anonymous Feb 08, 2013
    mine too help please
shaun taylor
Level 3:
  • Proscan Master 1,527 Answers
  • Posted on Mar 18, 2017
shaun taylor
Proscan Master
Level 3:
Answers
1527
Questions
0
Helped
338410
Points
3957
Hi i'd check the speakers first, test the ohms with a multimeter if ok you could have a bad amp ic on the main board, or a faulty capacitor,thanks
shaun
1 Related Answer
Anonymous
  • Posted on Oct 15, 2009
SOURCE: No volume on my Proscan 32LB30QD TV
how to hook a headset to a 32LB30QD
2answers
Need code for ProScan universal remote
Proscan HDTV Codes = 1000
Proscan TV Codes = 1000, 1008, 1068, 1094, 1108
Proscan DVD Codes = 2118, 2144, 2205, 2319
Proscan VCR Codes = 3000
ON MOST REMOTES:
1. Turn on the TV.
2. Press and hold the TV and SEL buttons simultaneously for 3 seconds. The button will light.
3. With the button lit, point the remote at the TV and enter the TV's 3, 4, or 5 digit code.
4. Verify by pressing the VOLUME + button. This should turn the TV VOLUME up.
5. Press the TV button to store the 3, 4, or 5 digit code. The button will blink twice to confirm the code is stored.
Your ProscanTV can be controlled with a universal remote and work with Comcast, Dish Network, Direct TV, RCA, etc...
2answers
Proscan website
Depend on the manufacturer. You may able to install.
ProScan TV - Movies playing on Blu Ray via ProScan TV are all in black & white. I am certain I have a connection wrong but can't figure out which one - the "names" of connections on ProScan a
why do not you try totalmedia? I have used it for almost 2 years and never had any problem. it plays blu ray on pc smoothly. when i bought it, to my surprise, it can change region code, thus i'm never worried about relaxing myself when on business. It's an easy to use and professional blu ray player software for windows; including Windows 8. of course, it fully integrates with Windows Media Center too. beyond your surprise, it's also a 3d video player.
What's your problem?RCA PROSCAN PS52800 52-Inch Digital High-Resolution Projection TV Monitor/Receiver, no audio
Audio circuit problem and likely parts are no longer available due to age of set----some shops may tackle this set for repair or not..........
2answers
Volume making humming noise when on
there is a bad ground.
the hum you are hearing is ac getting into the audio.check all the rca plugs on the set are plugged in all the way.do not run them close to a power bar either.
sometimes a second unit with it's own volume is hooked up to the tv and then the tv volume is up too high because the other box is turned down.if there is a unit hooked up,turn it's volume up ,and the volume on the tv down,otherwise the tv will amplify the residual noise.cheers,ed
12helpful
11answers
Proscan Tv is humming
This made my humming sound go away completely;
From JD at oncorpus.com [manufacturer of the 32LB30Q]
Please follow these instructions, should fix the hum issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone.
John
Top Proscan Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
