Question about Sony Handycam DCR-HC42E Mini DV Digital Camcorder
Sony DCR-HC42E not getting detected though i-Connect (IEEE-1394) connection with System loaded with Windows Vista
I connected the Sony DCR-HC42E unit to dell vostro laptop, installed with Windows Vista Home Premium, through i-link cable after installing PMB (Picture Motion Browser) Ver.5.6.02. When the link "Import from Tape (Handycam)" in PMB ic clicked, getting message "Cannot find the Handycam (Tape) Check the i.LINK connection to the Handycam." Checked correct installation of driver for IEEE-1394 port on laptop. Need help for correcting the problem.
Posted by O.P. Madhvi on
  • O. P. Madhvi Aug 01, 2012
    Subsequent to above observation, once handycam was detected by my laptop and I was able to download vdeo, but on next day it again failed to detect the DV rcorder. I also tried with another laptop installed with Windows XP, but haere again the DV was not detected. Looks like, there is some problem with the haddycam stationof the DV recorder. I am able to get USB streaming and AV output through the handycam station.
5 Related Answers
Simes
Simon
  • 33 Answers
SOURCE: I need drivers for DCR-HC42E
Go to Handycam DCR-HC42E downloads for the drivers, according to their matrix it depends on the model of handycam and what OS you are running whether you got the software bundled with it or not
Posted on Mar 03, 2008
david_brack
SOURCE: i.link cable for sony handycam
i-link it Sony's name for Firewire or IEEE1394. Any PC retailer and many online retailers sell the PCI cards (if you are using a desktop) or an adapter card if you are using a laptop. Before I give further details, it would be worth knowing if you are using a laptop or a desktop PC. Also, what country are you in - that would help identify potential suppliers.
The card and the adapters can be bought for around £10 - £20, and can be fitted easily. I don't know how much a computer store would charge - would guess around £30 - £40.
Firewire is also used for external hard drives, i-pods etc so it's probably worth having the ports at your disposal anyway.
Get back to me with further info, and I can point you more accurately in the right direction
David
Posted on Dec 02, 2008
Anonymous
  • 763 Answers
SOURCE: i link in DCR-HC 54 models
try to go here and download the driver or just look for your model and download on that link. install it to your pc.
http://www.sony-asia.com/support/download/1656/product/dcr-hc39e?site=hp_en_AP_i
try also here
http://download.css.ap.sony.com/consumer/IM/2584907131.pdf?p=1
CHARCOIS
Posted on Aug 24, 2008
Mitesh Kr Anand
  • 497 Answers
SOURCE: cant transfer videos to pc
Option 1:
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Option 2:
(Applicable for Windows XP Operating System only):
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Option 3:
If you are using an i.LINK cable then:
The Camcorder will flash the DV IN message as soon as the i.LINK/Firewire cable is connected to the Camcorder.
If you are getting the DV IN message then it indicates that the Camcorder recognize the connection.
If you are not getting the DV IN message as soon as the i.LINK cable is connected with the Camcorder then the issue may be with either the Camcorder or with the i.LINK cable.
Try resetting the Camcorder or try with different i.LINK cable. Locate the RESET button behind the LCD screen of the Camcorder. (You will be able to locate the RESET button by opening the LCD Screen. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object).
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
If the issue still persists after resetting the Camcorder and with different i.LINK cable then your Camcorder requires service to resolve the issue.
Good Luck!!!!!!!!!!!!!!!
Posted on Sep 18, 2009
Davidivory1
David Webb
  • 338 Answers
SOURCE: I have replaced a Windows XP PC with a new PC
Mostly with these cameras you do not need driver (unless you use a USB cable) but like me you have firewire okay? so you should unplug your camera, turn your PC off for a min or two, plug camera in THEN yes THEN put your PC on, and the Win 7 will see your camera and loads setting it needs auto ok.
Posted on May 29, 2010
I purchased a Pinnacle Dazzle to connect my Sony DCR-HC38 to my computer. I do not know how to connect the camcorder to the Dazzle device.
Sony DCR-HC38E should have an interface called 1394, or the firewire. so you need to use a FireWire cable to connect it to your computer's firewire interface, some laptops have it built-in, If you don't have one on your computer, you can either purchase a IEEE1394/FireWire adapter, which should be under 100 or even $50.
Connector Type1.0 x Composite video/audio output , 1.0 x S-Video output , 1.0 x USB , IEEE 1394 (FireWire/i.LINK)
Sep 09, 2011 | Sony Handycam DCR-HC38E Mini DV Camcorder
I dnt hav usb cable for my handy cam DCR-HC52E ...
Product Summary
    4-pin to 4-pin IEEE 1394 iLink FireWire Cable dv out to laptop Connect and transfer home movie from your digital camcorder to Notebook computer.
    You will need a Firewire port on your computer, also known as a DV port or IEEE 1394, to use this cable. This is NOT a USB cable.
    This DV cable will connect your laptop (notebook)
    NOTE: for some models, becuase of no DV jack on the body, this cable connects to docking station/cradle instead of connecting directly to your camcorder.
Mar 20, 2011 | Sony DCR-HC52E Mini DV Camcorder
CAN'T RECOGNIZE MY SONY DCR TRV720 HANDYCAM CAMCORDER ON WINDOWS XP 5.1 SVC PACK 2 BUILD (2600) TOSHIBA SATELITTE 5005-S504 LAPTOP. IEEE ILINK CABLE 1394. NEW CABLE 4PIN TO 4 PIN. SONY SITE SAYS, DONT...
There is a Sony tutorial page for downloading video to computer at THIS LINK
You will need to select Windows as the operating system, then your camera type, then select the type of connection.You are strongly recommended to use i.Link (which everyone else calls Firewire).
There is Sony software called Picture Motion Browser that you can download (you will need the number from your original CD).
If none of that helps, perhaps the driver for the Firewire (IEEE 1394) port on the computer needs to be reinstalled. You can view this driver (if it is installed) by opening the control panel\system\hardware\device manager and looking for IEEE 1394. It should say if there is a problem or if it is working. You can force it to reinstall at this point.
Jan 26, 2011 | Sony Handycam DCR-TRV720 Digital Camcorder
I have a sony handycam dcr-hc19e. I am trying to transfer to my laptop which only has a usb connector and i have updated software still wont work - any ideas?
If you computer has Windows Vista or Windows 7 installed, then streaming over USB is not supported on those operating systems.
It is only supported on Windows XP.
At any rate, the quality of the video when streamed over USB is of considerably lower quality when compared to the video when transferred of IEEE 1394 connection.
If you don't have Windows XP, you'll have to find a computer with an IEEE 1394 connector and buy a Sony DV to IEEE 1394 cable. The DV port on the camera is right next to the USB port. Consult your local Sony retailer to find the proper cable for your camera.
Dec 30, 2010 | Sony DCR-HC19E Mini DV Digital Camcorder
I cant download my DCR-TRV250 Digital 8 videos to my computer. I tryed on Win 7 and Win XP, with or without Sony drivers... But no computers recognize my cam. Also I looked for help on Sony eSupport, but...
From the Sony support page for this camera, it has the following:
  • Drivers:
    • The drivers needed to connect your Sony camcorder to a computer and transfer files are already included in the operating system.
  • Not Supported:
    • The USB streaming feature is not supported with the Windows 7 operating system.
    • The Windows 7 Starter edition is not supported.
From the user manual page 184, they explain how to connect a iLink (IEEE 1394) cable from the camcorder to your computer. Since "USB streaming feature is not supported with Windows 7" as stated above, you now how to retrieve your video using the iLink connection instead.
Unfortunately, the camera does not come with an iLink cable, so you have to buy one. Additionally unfortunate is the fact that many computers do not have a IEEE 1394 connector to use with the iLink cable. As a result, you have to buy an adapter card for your desktop computer or hope that your laptop has a built-in IEEE 1394 port.
Once you get the iLink to IEEE 1394 issue resolved, you can then use the software provided by Sony or any DV capture software to download high quality copies of the video from your DCR-TRV250.
Dec 30, 2010 | Sony Handycam DCR-TRV250 Digital Camcorder
Where can get the sony handycam DCR-HC42 device drivers support Windows vista
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
Aug 31, 2009 | Sony Handycam DCR-HC42E Mini DV Digital...
Fireware port is not sensing Sony camcorder
check if vista home edition supports it. other else uninstal & reinstal the driver.
Jul 03, 2009 | Microsoft Windows Vista Ultimate Edition
A sony dcr-trv 103 camcorder and I want to connect to computer
Yes, the brandnames Firewire (Apple) and iLink (Sony) are both IEEE 1394 interfaces.
Your cam should require a 4-pin to a 6-pin, both IEEE 1394. Hope this helps.
Apr 20, 2009 | Sony Handycam DCR-TRV103 Digital Camcorder
Detection of my digital camera
if your pc has firewire IEEE 1394 ports then it does not need them added, if it does not then it needs them added,
firewire, IEEE 19394 cables have a pc end that is flat D shaped and a device end that is rectangular with one side bent in.
if you have a socket on the backplane of the pc that looks like the ones in the background
f2339e9.jpg then you have firewire, else you can buy a pci firewire card for any vacant slot for ~$20.00
Jul 17, 2008 | Sony DCR-HC19E Mini DV Digital Camcorder
SONY HANDYCAM DCR-TRV280
To download video you need Firewire port, also known as an IEEE 1394 port.
Windows XP or Vista can save your video files.
PCMCIA 2-Port IEEE 1394 FireWire Laptop Cardbus PC Card
Jun 26, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Sony Handycam DCR-HC42E Mini DV Digital Camcorder Logo
232 people viewed this question
Top Sony Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Larry Stiles
Larry Stiles
Al Rush
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
