Accelerating, car goes ok, slowing down, braking is ok it's when I 'roll' to slow the car I hear a small 'crying' high pitch noise which starts high then slowly dies away once car fully slowed/stopped. Any idea of what it might be. Car is only 7,500 kms old, has had 2 services. Thanks in advance.
SOURCE: 2001 Hyundai Accent dies while driving
I had a similar problem and had an engine tune up done and the car runs almost like new now. Mine is a 2001 Hyundai Accent too.
SOURCE: Hyundai Trajet automatic output speed sensor problem
Priced new output speed sensor €190, went to breakers yard, found similar sensor on mitsubsihi carisma, purchased €20, fitted same no problems since. Touch wood!
SOURCE: cuts off when I slow down or stop doen't do it all the time
dear friend-you are quite correct when you suspect the TPS sensor,im sure that your vehicle is a automatic which makes it worse.have it checked out.
SOURCE: Slow pick-up, high rpm
Do a full Service air filter oil transmission oil brake fluid radiator the 9 yards this should help some if not then you should take it to a mechanic to have your transmission tested or you can use lucas transmission stop slip
SOURCE: 2000 hyundai accent code 302 misfire and slow responce o2 senser
Yep!.. Typical with an engine cylinder misfire. Inspect the plug and ignition wire, especially the insulator. If you see a 'christmas tree' pattern on the insulator, that's where your problem is.
