Question about GE Freezers
GE Freezer Model FUF17DMAR Compressor does not come on
Model FUF17DMARWH. Came out of storage, plugged into outlet, turned thermostat up until compressor came on. Compressor ran for awhile, the outside of the side walls got very hot. After a short time, the GRI outlet popped (it was reset) and now the compressor will not come on at all (although the inside light works). I suspect the Thermal switch has tripped, but I don't know where it is or how to reset it. Does someone know?
Posted by JPGolberg on
  • JPGolberg Jul 21, 2012
    As an added comment, with power to teh inut (the light works), when I turned the thermostat dial in the right side of the inside of the unit, it never "clicks", to turn the unit/compressor on.
5 Related Answers
robert samples
  • 1314 Answers
SOURCE: Kenmore
when its running how hot are the sides the starting amps are too high and 1.5 running amps ain't bad now the the cut in cut out are too high if you look on the dial that the mid point settings that's where you should have it not on 1 1 is hot set it on the straight line that's where you should do all your testing colder settings go up not down you could be overheating the compressor by making it come on too quick the freezer should be about -10 or so do you see any gaps in the gasket
Posted on Mar 31, 2008
22yooper
James Helmer
  • 828 Answers
SOURCE: Freezer not getting cold enough
I think your system has a leak and has lost the refrigerant charge.
The only way to check is by accessing the sealed system. Most systems are covered for five years on the compressor. Contact the place of purchase and give them your indications for your problem.
Posted on Jul 06, 2008
Anonymous
  • 323 Answers
SOURCE: Kenmore Upright Freezer Alarm
1. You can hear the compressor running.
2. The temp setting you turn the thermostadt to starts and stops the compressor.
3. Look in your manual for a reset button and the location.
4. If you are familiar with a meter, grab the manual and check it it. But I doubt it is the resistance.
5. Sounds like a bad motor or low freon. If you have a lot of food in it, and the above didn't work, bite the bullet and call a repairman, although it sounds like much of the food is past saving if it is really defrosted.
Posted on May 12, 2009
Maytag317
Victor
  • 1136 Answers
SOURCE: Freezer outside walls are very hot. Not maintaining temp
Hi, The walls are getting hot because that is where the condesor coils are. The condensor coils are where the heat is disperst that is trap as the coolant pumps through the evaporator coils inside. The fact that it is holding 0 degrees is a good sign. Is this freezer in a garage?
Check the door seals to make sure no heat is getting into the freezer other then when the door is opened.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 24, 2009
nnesmith
harold nesmith
  • 162 Answers
SOURCE: Outside of chest freezer gets hot
it is normal for outside to get hot. that is where the condensor coils are located. if unit is working don't worry.
Posted on Jul 26, 2009
Why My haier model hcm070la Chest freezer the compressor is not kick on
check thermostat, or relay on one side or back cclose to the compressor area there is a removable lid. removed and look for a thermostat disconect the 2 wires and bridge them then plug the the freezer on if runs replace the temp thermostat for a new one should be freezer thermostat
Nov 07, 2016 | Haier 7 cu. ft. / 198 liter Chest Freezer...
My artic freezer f22cwf4 compressor is not turning on. I have replaced the thermostat and all the fans are working. The unit is only 6 years old.
Not an expert opinion but seems that either you have low refrigerant and maybe the compressor is not therefore starting or the compressor has an issue, or the power to the compressor is missing.
Oct 16, 2014 | Artic Air Used F22CWF4 White Commercial...
Electrolux freezer will not turn on automatically when termperature warms in compartment, controls don't appear to turn compressor on, any help would be appreciated?
Sounds like your thermostat is bad. You probably have to replace it and the sending unit also. Big job! Look for a manual at : http://www.servicemanuals.net
Apr 28, 2014 | Electrolux Freezers
I have an upright freezer Kelvinator I got it at a garage sale, we brought it home and it has sat for a while and we never tried to get it to work until now, it doesnt turn on at all no light, no sound,...
I looked at the parts diagram (GE model#FUF14SUDRWW) on Searspartsdirect. I didn't see an actual on/off switch, but it does show a temperature control switch in the inside of the unit. On some of the freezers, if you turn the knob all the way to the left, it acts as an off switch and kills the unit. It looks like the knob inside the cabinet, on the lower back right side (it could be upper..hard to tell by that diagram). If there is no knob, but an empty hole, then the knob is missing and you might have to turn the shaft with pliers to check it. If you get a click at one limit of the switch when it is turned, that means it is acting as an on/off switch. If nothing happens when turning it after the click, I would suspect a bad switch. Since the lights nor compressor are working, it would point at a switch. You can probably find it cheaper than Sears by googling the part # WR09X10064. I saw it as low as $84 at some of the appliance parts site. A local place might have a used one for cheaper.
Hope this helps
Aug 16, 2011 | GE 13.7 cu. ft. General Electric Upright...
My ge upright freezer is getting cold, but it is not freezing the food
check the door is closing tight first,,if it is try turning the thermostat down a bit more,,if that dont work you may need a new thermostat fitted and maybe even a re-gas and a new compressor
how old is the freezer???
Aug 21, 2010 | GE 16.7 cu. ft. / 473 liter Upright...
Just bought a used GE chest freezer model FH5DSAWH from friends. Brought it home plugged it in and it doesn't get cold. Can hear it running and the compressor gets hot. Any ideas? Was told it worked great....
your ptc overload relay on the compressor is bad,unplug it off the compressor and get a replacement at an appliance parts store,plug in the replacement and this will solve your problem
Apr 27, 2010 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
Won't turn on
To determine which component has failed please do the following.
Unplug the freezer wait 5 minutes and plug back in. Listen closely for any sounds by the compressor. If you hear a click or hum followed by a click the problem is the compressor and would cost about $400.00 to repair.
If you do not hear any sounds the problem is most likely the cold control or sometimes called the thermostat. The part number is WR09X10053 and is about $25.00
Apr 25, 2010 | GE 5 cu. ft. / 142 liter Chest Freezer...
High Temp light will not go off even though the freezer seems to be working. Compressor does not stop running
What makes a compressor to run constant is the thermostat. Bang on it to see if it will turn off. turn the setting to 1. if it still wont shut off replace cold control (aka thermostat)
worry about the light later hope this was helpful
Mar 29, 2010 | GE 13.7 cu. ft. / 388 liter Upright...
When I plug my freezer to an outlet not gfi protected it works fine, but when I plug it into an outlet that is gfi protected it pops the breaker. I dont understand why.
All fridge and freezers should be plugged into an NON-GFCI protected outlet, since the inital start of the compressor can cause the GFCI to detect a millivolt surge, when the compressor starts, causing the GFCI to trip.
If this is in a kitchen, you should change out the outlet to a non-GFCI outlet BUT only to a single outlet that only has the freezer plugged into.
If it's in a basement, garage, or some other place with a GFCI outlet, you can change out that one outlet to a standard single outlet device of which ONLY the freezer will be plugged into and remain code compliant. You will need to make sure that any other outlets served by that current GFCI outlet stay protected, by installing the GFCI you swap out, and put it in place of the NEXT outlet in the circuit.
By doing that, you will have the first outlet that was the GFCI, now a single outlet NON-GFCI serving the freezer, but the next outlet in the branch circuit gets a GFCI outlet, thus protecting the rest of the circuit, in compliance with the NEC (National Electric Code)
If you need further help with this, please comment back and I'll check back later and provide you more detailed info. Of course, be sure to turn off the breaker to this circuit before making any changes to the outlets, etc.
Hope you find this Very Helpful and best regards!
Aug 21, 2009 | GE Freezers
Not Freezing, but cold
The thermostat should be a close circuit when requesting cold temps. or when asking the compressor to come on. The exterior surface on some freezers warm when asking for cold inside. Yours has a condenser coil on the back and that should warm when cooling. If compressor is runningit should be wrm if no freon has leaked from freezer somewhere.
The defrost timer should rotate clockwise during the day and give approx. 3 defrost daily or about every 8 hours. Until the thermostat is resolved and asks for a closed circuit the compressor will not come on. Unplug freezer from outlet,remove thermostat wires, then turn the thermostat to its coldest setting and check again. If no closed circuit the thermostat will need replaced first. Hope this has helped you, Sea Breeze
Nov 01, 2007 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezers Logo
243 people viewed this question
Top GE Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a GE Freezer Expert? Answer questions, earn points and help others
