Have replaced the follow blower motor,and resister,relay,climate control box, could it be the head unit, nothing works . blower doesn't come on compresser doesn't come on just none of the ac componets work
You can test where is th problem with the J2534 interface first, and then fix the problem. If you couldn't do this, you should take it to near garage.
SOURCE: The air conditioning does not work on my 1999 VW
Typically, AC will not work because of a low charge. You can prove or disporve by jumping the low pressure warning switch. If the AC runs when you jump it, you have a low charge. If it will not run when you jump it, you have other troubles.
Freon is dangerous. Please dont try to charge your AC yourself.
Thank you for your interest in FixYa.com
Fig. Fig. 2: Remove the glove box and frame
Fig. Fig. 3: Air conditioned models require the removal of the control unit. Handle it carefully
