I moved the Dehumidfier to a differnet location and stil the same tells me bucket is full and CH appears
SOURCE: dehumidifier
IS THE ROOM HUMIDITY LOW. IF IT IS BELOW 30% THE HUMIDISTAT WILL SHUT DOWN THE UNIT. THE AMMBIENT TEMP SHOULD BE ABOVE 65 DEGREES AND THE HUMIDITY SHOULD BE ABOVE 50 %.
SOURCE: unit only runs a few seconds and then shuts off
If the water reservior is empty then the float is stuck in the full position.
SOURCE: dehumidifier reads CH 01 Bucket
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
l'';';l
SOURCE: I turn on the dehumidifier and the red indicator
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
heatman101
