Question about Dell Dimension E520 PC Desktop
Floppy diskette seek failure fix - Dell Dimension E520 PC Desktop
Posted by D. Zayas on
Walter H Boehm
  • Dell Master
  • 998 Answers
The selection for the floppy drive will be set to ON. If you do not have one then you must disable floppy in set up (BIOS) menu.
You can enter the set up (BIOS) menu by tapping the F2 key.
Posted on Mar 22, 2014
5 Related Answers
Anonymous
SOURCE: floppy diskette seek failure
F2 Scroll down to "Drives" and open the menu. choose "Diskette Drive" and turn it "Off".
Posted on May 19, 2008
Anonymous
  • 326 Answers
SOURCE: my pc go to diskette drive 0 seek failure
U'r hard drive is not communicating with the system. Open the pc (power off) and check the cable connections. While U'r there, clean with blow or vac. U'r HD may have died. The data may still be there and got to with a new hd.
Posted on May 23, 2008
Anonymous
  • 123 Answers
try to go to bios set up..then change the boot order..in the boot tab,,change the "first boot" label with hard disk..then it wont seek for floppy again..
Posted on Jan 05, 2009
Anonymous
  • 61 Answers
try to go to bios setup and change the boot priority for the devices, by setting first priority to your Hard Disk , and then your CD Rom and last to the floopy disk..
Posted on Jul 10, 2009
tbirdfan1
Michael Thomas
  • 3056 Answers
SOURCE: Floppy Diskette Seek Failure on boot up
Hello there:
This is a setting in the bios , so what you are going to have to do
is boot into bios and under the boot section and check to see if the floppy drive is a option that is part of the boot sequense if it is change it so that is not part of the boot sequense than go under the periphial section and check to see if it is showing up there as a removable device if so change it or disable it all together since you do not have a floppy drive ok
and this should take care of he problem
I hope that this is very helpful for you
Best regards Michael
Posted on Dec 06, 2009
My dell c521 says diskette drive 0 seek failure
You need to press f2 then go to Standard CMOS Features, then highlight drive A. Change it to none. You should not have anything in there enless you have floppy drive
Jan 14, 2014 | Dell Dimension C521 PC Desktop
The floppy disk or drive is damaged, or if your trying to boot your computer and you have a floppy in the drive that is not bootable. It will try and boot from floppy first then cd then hard drive usually but floppy's are stupid and only return an error and then stops. Remove the floppy disk and boot
Dec 06, 2013 | Dell Dimension 5100 (D51L1) PC Desktop
My computer keeps reading diskette 0 seek failure on a black screen and wont start how do I fix this issue. I have a dell desktop computer
You might get this error if there is a non-bootable diskette in the drive. Remove it if so and you might have a normal star-up.
If there is no diskette in the drive, you may have a hard drive failure where the computer can't start normally and is switching to try the floppy.
Apr 13, 2013 | Dell Vostro 200 PC Desktop
Dell optiplex 745 Floppy Diskette Seek Failure
how to solution. Dell optiplex 745 Floppy Diskette Seek Failure
Jan 20, 2012 | Dell Computers & Internet
"Floppy Diskette seek Failure Strike F1 key to
maybe the floppy disk drive is defective or maybe the IDE cable is deffective, or maybe the cable on the floppy drive is not properly inserted , try to replace IDE cable of the floppy drive if still the symptoms happens replace the floppy drive
Jul 20, 2011 | Dell OptiPlex GX520n PC Desktop
Boot up screen says "diskette drive 0 seek failure"
Press F2 look through the menus and remove / disable 3.5 floppy drives.
Jan 06, 2010 | Dell Dimension 8400 PC Desktop
Boot into setup by pressing F2 or F10 depending on your bios and disable the floppy drive setting.
Jan 14, 2009 | Computers & Internet
Jan 03, 2009 | Dell Dimension E310 PC Desktop
1st-replace the ribbon cable for floppy, see if that works,2 nd replace floppy
May 02, 2008 | Dell Microsoft Windows XP Home Edition
Jan 14, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension E520 PC Desktop Logo
168 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
